Author Topic: Alternator bushings?  (Read 3581 times)
mgold
    • http://homepage.mac.com/mgold/BMW/PhotoAlbum42.html
« on: June 18, 2006, 12:15:40 AM »
So I'm about ready to install the AC idler that I got from Denis and while I'm at it, replace all the belts.  Now, a few months back at a local meet, someone noticed that my alternator was sitting a bit crooked and mentioned that it was likely my alternator bushings gone bad. I totally forgot about it until now.  My question is has anyone else had an issue with their alternator bushings gone bad?  If so, which parts should I get?  I was looking at things today and it looks like its simply mounted cock-eyed (probably by the dealer who replaced my water pump a few years back).  Thoughts and suggestions are welcomed.
mgold
« Reply #1 on: June 20, 2006, 01:02:53 PM »
bump... anyone, anyone?
M42boy
« Reply #2 on: June 20, 2006, 01:18:17 PM »
Unbolt the top alernator bolt mount and inspect them.  You can simply take a screwdriver and drive them out when the bolt is removed and the alternator swung out of the way.
They aren't really doing much but dampening some vibration, so I suspect they are probably fine.  Someone makes poly alternator bushings for these cars, but that seemed a bit over the top, even by my standards.
M42boy
« Reply #3 on: June 20, 2006, 01:20:42 PM »
Ooh, I forgot, you will need to loosten the slack on the belt and remove it from the pully first!  My motor was on an engine stand and no belts when I did this.
mgold
« Reply #4 on: June 21, 2006, 12:46:37 AM »
Thanks.  I'll be swapping belts anyways so it'll be off when I inspect it.
