I replaced my valve cover gasket 2 days ago, since I was going to change the oil anyway and some of the bolts on the valve cover were not properly torqued, and I also checked the lower oil pan while I was at it, and found 3 screws lying on it. I heard it is not uncommon, nor good, since it may affect the oil pickup, depending on which bolts are loose, I believe. It all took longer than I would have wanted, but in the end I managed to put it all back together. No apparent damage or anything wrong when removed the valve cover. Engine was running smoother afterwards, but to my surprise now there´s a leak. Not from the valve cover gasket (as it was before, that´s what led me to this), haven´t been able to pinpoint where from since it has been raining for the last 2 days. What weirds me out is the yellowish/greenish-oily stuff that leaks from my car. I´m assuming there´s coolant leaking into the engine. But where´s it leaking in there through? and where is leaking it out from? I might be able to figure all this out tomorrow ´cause I don´t have to work. It smells very lightly like burnt oil, there´s no overheating. Is it too bad to drive a few miles here and there before I get this fixed?
