Help Ordering Custom Pistons!
Author Topic: Help Ordering Custom Pistons!  (Read 3585 times)
crazzy_hippo
« on: November 06, 2008, 11:30:54 PM »
Hi guys I need some help ordering custom pistons. Is it necessary to fill in all the details on the forms. What if there are details I don't know about? This is because I am trying to ask wiseco to custom pistons for my engine but I have no idea about some (or rather most) of the details to fill in. Things like deck clearance, valve pocket depth and angle etc.
I have got not idea what are they and how to get the measurement at all.
Btw, I also need some advice/suggestion regarding my engine project. I am trying to build a M42 motor thats similar to MM's design but at a lower price. So far, I have managed to source for a M47 crankshaft, Eagle M50 conrods. Thus all thats left are the pistons. I did thought about using MM pistons but the Eagle rods are longer than the MM rods.
I am planning a compression of 9:1 running 14-15PSI of boost using a supercharger. Do you think this configuration is OK or is the compression too high for the boost?
Thanks!
1991 E30 M42
« Reply #1 on: November 06, 2008, 11:39:22 PM »
if you are having issues ordering pistons I don't think you should be trying to build an engine
crazzy_hippo
« Reply #2 on: November 06, 2008, 11:59:33 PM »
Quote from: 1991 E30 M42;60138
I am not building the engine. I am getting someone else to do it. But I need to supply him with the parts.
« Reply #3 on: November 07, 2008, 01:20:56 AM »
Quote from: crazzy_hippo;60137
Thanks!
depends on if you have a good tune or not.  You don't need low compression for high boost.  :rolleyes:
bar73k
« Reply #4 on: November 07, 2008, 02:20:41 AM »
i got my pistons made through topend performace, all i needed to supply was what motor they were for, what compression ratio i wanted and what size e.g. standard, or over sized
crazzy_hippo
« Reply #5 on: November 07, 2008, 11:05:14 PM »
Some updates. Wiseco has gotten back to me. This is the reply.
Small resume:
Block M42B18 bore will go from std. 84 to 86.0 mm.
Piston pin 22 mm.
Stroke std. 81 will become 88.0 mm
Compression height  std. 31.65 mm. + 5.00 mm. ( due to the shorter rod)  - 3.50 mm. ( due to the longer stroker) makes CH. 33.15 mm.
Displacement will raise from 449 cc to 511 cc Compression Ratio will go from 10:1 to 9.0:1 so you'll need 14 cc extra volume in the piston dish.
Do you you agree with this layout? Price for a 4 piece kit with rings, pins and a skirt coating will be € 704.20
Vriendelijke groet / Kind regards.
crazzy_hippo
« Reply #6 on: November 07, 2008, 11:05:59 PM »
Small resume:
Piston pin 22 mm.
