Author Topic: Hissing noise at startup  (Read 3827 times)
16v of E30
« on: November 03, 2008, 02:36:55 AM »
Happends occasionally, when i start the car. Usually when i turn the car right over, i get a hissing noise under the hood, but the car always starts without hesitation.  anything like this happen to you?
Cobra Jet
« Reply #1 on: November 03, 2008, 09:34:44 AM »
Nope.
Check any or all rubber vacuum lines under and around the intake (both upper & lower).  Also, check the large rubber air intake tube going from the headlight bucket on the driver side to the airbox assembly - this tube is known for cracking due to age & engine heat.
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
JP 91iS
« Reply #2 on: November 03, 2008, 12:03:00 PM »
Well if the car starts without hesitation and idles fine I wouldn't suspect a vacuum leak.  You should have someone else start the car while you listen around the engine bay, maybe its not really a hiss.
-JP
Project M42: generating funds
16v of E30
« Reply #3 on: November 04, 2008, 12:17:01 PM »
yeah its weird...happens one in 5 startups...
was thinking it was fuel lines getting primed?
EN318isPDX
« Reply #4 on: November 04, 2008, 01:55:24 PM »
Quote from: 16v of E30;60033
Could be, fuel likes to make a hiss noise when it leaks.. I'd start looking for fuel leaks
16v of E30
« Reply #5 on: November 07, 2008, 05:53:23 PM »
no leaks...
