Help please - i am stuck!!
My 318is was running lovely. All of a sudden i started it and it was running like a plug was fowled up and started backfiring.
After doing a few checks, a friend thought it might of been a valve problem as no's 1 and 4 were not responding to plug lead removal although there was spark.
I ended up removing the head but all is fine. I have replaced the head but the car is still running rough. I now also have a problem where the injectors on 2 and 3 are pumping fuel out of the inlet manifold and down the side of the block. I checked the seals and ended up swopping them with 1 and 4 but they are still leaking, therefore not a seal problem. Think that they might be overfuelling but not sure if they would pump fuel out if that happened.
So in a nutshell:
Head and valves fine
Timing is spot on
Spark is fine
overfuelling on 2 and 3, but suspect that no fuel to 1 and 4, hence misfiring.
Can anybody shed some light on this one
Thanks
