Author Topic: business cd radio  (Read 6667 times)
Jose Luis
business cd radio
« on: October 23, 2008, 11:20:53 AM »
does anyone install a business cd radio CD43 from a E36 on a E30??
business cd radio
« Reply #1 on: October 23, 2008, 05:50:39 PM »
i found this on the superweb
looks nicer than all those flashy gadgets aftermaket ones
http://i115.photobucket.com/albums/n300/bearing01/Boot_016.jpg
cabin
business cd radio
« Reply #2 on: October 24, 2008, 06:38:50 PM »
I'm working on installing a C33 radio from an E36, but it's the same idea.
You are going to need the wiring harness for the stereo from the E36 and wire it in to the E30 harness.  They also sell an adapter, but I got the harness for free from the junkyard, so that is the way I went.  Speaking of adapters, you are going to need an adapter for the antenna as well to go from the E30 plug to the E36 style.  I believe Metra and Scosche(sp?) sell them along with BMW (part no. 65 12  1 388 950, $23ish from the dealer).  Also, it will not sit flush in the dash unless you grind the lip down where the HU slides in.
It will also be a good idea to get a separate amp to run the speakers as the CD43 was designed to work with the stock, amplified systems in the E36.  Without running a separate amp, you won't be giving the speakers much power and the HU will most likely get very hot.
Check out r3vlimited, there are a whole bunch of threads regarding C33, C43, and CD43 into an E30.  Mine's all wired up (no amp for now, not worried since I have a spare C33) and I just need the antenna adapter and security code.
rx82000
business cd radio
« Reply #3 on: March 08, 2009, 02:55:00 PM »
Do you have the link to the adapter?
Bottom line, I'm trying to use my Ipod in my car. I currently have a stock Pioneer radio.
Looks like I have to upgrade to C33 or C43 to use a Dice device.
Thanks.
rx82000
wire harness adapter
« Reply #4 on: March 09, 2009, 09:13:05 PM »
Here is the wire harness adapter that I found:
Metra Electronics Corp. - 70-8590
http://www.metraonline.com/products.aspx
Looks like there is no need to splice the wires in the car but rather connect this adapter to the aftermarket piece.
Looks like i'm going to go aftermarket:
http://www.blaupunkt.com/us/7648002310_main.asp
Check out the pros for this one HU
1 - German
2 - Amber light (light color is controllable)
3 - Reads SD cards
4 - Blutooth if you get an extra piece
http://reviews.cnet.com/car-audio/blaupunkt-brisbane-sd48/4505-3425_7-32957749.html
rx82000
business cd radio
« Reply #5 on: November 03, 2009, 11:46:35 PM »
Adapter is a piece of Shi**. Don't buy it.
Anyways I installed the Blaupunkt Brisbane SD48 and I'm really happy with it. Reads SD memory cards
