Author Topic: Cooper S supercharger  (Read 5388 times)
ChItalian1027
« on: October 23, 2008, 12:18:34 AM »
hey guys i was wondering would a cooper s supercharger fit onto the m42?
thanks
Greg
'95 318ti
'04 Mini Cooper S
ose30
« Reply #1 on: October 23, 2008, 12:27:02 AM »
Has been done
nuvolarossa
« Reply #2 on: October 23, 2008, 01:29:32 AM »
sure but it's better the M62 from the benz 230kompressor, as it's shorter and it has bigger displacement.
The Mini cooper S s/c has been fitted on a e30 by user "Appletree IS supercharged". Here are the pics: http://www.m42club.com/forums/showpost.php?p=58768&postcount=6
There was a member of bimmerforums, "frankie1000" that fitted it on a e36: http://forums.bimmerforums.com/forum/showthread.php?t=221624&highlight=frankie1000 but thread was old and pics are dead.
IMHO the M45 has a big case, but small rotors, so that it will need a lot of space to be fitted and it will easily run out of steam.
If you plan to do a such thing with a eaton, do it with the M62, at least it will have the same expandability as DASC.
As you can see appletree is searching for a bigger supercharger, as he wrote that his m45 (the one from mini cooper s) is at maximal revs and can't do more than 8 psi... and if you know about eatons and their pulley ratios, they at max revs are pretty inefficiently (the air that the s/c send to the engine will be very HOT when high revving the S/C :D )
ChItalian1027
« Reply #3 on: October 23, 2008, 01:20:21 PM »
thank you guys. i will probably go with the M62 s/c from what i have heard here.
do u know if he was doing a stand alone software? and was did he have a intercooler?
« Last Edit: October 23, 2008, 01:24:09 PM by ChItalian1027 »
Greg
'95 318ti
'04 Mini Cooper S
GrindCulture
« Reply #4 on: October 23, 2008, 01:33:07 PM »
Pretty sure Appletree is running on Megasquirt and it isn't charged cooled in any way.
E30 M42 Touring rightness!
« Reply #5 on: October 23, 2008, 02:07:39 PM »
Hi yes you can use a copper s one but a m62 would be better.
My m45 is running 8psi on standard internals and making 205bhp
It isnt running megasquirt but it is running stand alone managmnet called Emerald running spark and fueling.
It is also running charge cooling using laminova style charge coolers in the inlet manifold.
Cheers matt
GrindCulture
« Reply #6 on: October 23, 2008, 04:22:14 PM »
:D How useless am I!?
ChItalian1027
« Reply #7 on: October 23, 2008, 11:11:02 PM »
thanks matt.
i may go with the m62 or just go with the cooper s/c since i don't want to much power
Greg
'95 318ti
'04 Mini Cooper S
