Author Topic: M40 clutch info needed.  (Read 2485 times)
big red
« on: October 22, 2008, 01:25:57 AM »
:confused:  After trying to get a clutch for most of the week, I finally figured out why it's been such a pain. :(
Someone before me was nice enough to put in a M40 flywheel & clutch. I wish I knew that sooner.
( If it wasn't for Cobra Jets link to Motortraders last may, I still wouldn't know).
Again, as always, my questions are answerd at 'the club':D My humble thanks!!! :)
  I am wondering what make/ model/ year/ clutch kit I need. The write up said any M40 was a straight swap, but I don't know enough of  bmw's history to know which cars they came in, so I don't know what to order.:o
  If anyone knows and wouldn't mind shareing, I would greatly appreciate it.
Here's a couple of pic's incase I'm wrong about it being from an M40.:rolleyes:
Any info, comments, help, etc... is greatly appreciated. :)
  Thanks !!!!
hesgone2fast
« Reply #1 on: October 22, 2008, 02:39:39 AM »
The M40 engine came in the following models:
88-91 E30 318i
88-91 E30 316i
In the E36s, the 8-valve engine is called M43, which is basically the M40 engine, it might have the same flywheel though...
Check part numbers on realoem.com
Wise Old Dog
« Reply #2 on: October 22, 2008, 05:40:51 AM »
The clutch used is the same one as a 1991 318is NON-AC clutch. You should be able to find a listing for it. I have the same set-up. You should have the flywheel lightened and balanced while it's out. Mine is down to 17 lbs. I believe the stock unit weighs 22.5 lbs.
