Slammed Look?
Author Topic: Slammed Look?  (Read 5832 times)
E30Reich
Slammed Look?
« on: June 12, 2006, 12:12:38 PM »
I am trying to get a Slammed look and have been told to get FK 60/40's but I am unable to find them stateside anymore.  and I contacted some tuner shops that carry KW's for a KW 55/55 and they said KW doesn't make suspension kits that fit my application.
anybody know of any retailers that sell these kits or a suspension setup that will give that Slammed look.
Slammed Look?
« Reply #1 on: June 12, 2006, 02:51:52 PM »
the spax kit is a very slammed look.  Also you could get GC's and slam them.
The solution..
« Reply #2 on: June 12, 2006, 05:03:13 PM »
Use 6" - 2.5" I.D. - 225# springs on the front and 6" - 2.5" I.D. 300# springs on the rear - both without coilover adjusters. Shim them if it's too low. Drive very carefully and buy a lower oil pan now because it won't last long on a slammed E30.
« Last Edit: June 25, 2006, 03:19:00 PM by D. Clay »
M42boy
Slammed Look?
« Reply #3 on: June 12, 2006, 05:41:01 PM »
If you like the slammed look, the H&R Cup Kit is a good choice.  I like the looks of them, but they aren't much stiffer than stock, so it's more of a "style" kit.
I'll be posting pics of my Vogtland sport kit soon.
e9nine
Slammed Look?
« Reply #4 on: June 12, 2006, 08:01:27 PM »
If you want to SLAM your ride, get a skid plate. Our cars seem to have the lowest of all oil pans on e30s. Even though we have a 2 piece deal, you will sometimes crack both upper and lower oil pans.
As to the H&R cup kit, I know someone who had it and fuxxored his upper and lower oilpans. He didn't do it on purpose - you can only drive carefully to a certain degree and swerving a man hole cover or huge pothole is always easier said than done
E30Reich
Slammed Look?
« Reply #5 on: June 12, 2006, 08:25:25 PM »
How low is the H&R Cup Kit?
anyone have any pics.
And where can a skid plate be purchased besides the dealer?
« Last Edit: June 12, 2006, 08:44:23 PM by E30Reich »
///Motorsport
Slammed Look?
« Reply #6 on: June 25, 2006, 11:35:22 AM »
if HR cup kit will make you hit, people with IE#s probably have the same amount of worry.  Does anyone have a BMW part # for a skidplate?  i have seen them for the m20 e30s...
Slammed Look?
« Reply #7 on: June 25, 2006, 12:41:45 PM »
Quote from: E30Reich
Check 666 Fabrication for a skidpad.
e9nine
Slammed Look?
« Reply #8 on: June 25, 2006, 02:28:44 PM »
Quote from: ///Motorsport
Don't forget it's the spring rate that's the variable here...the H&R cup kit is not oriented for off-street performance unlike the Stage IIIs. Two cars can both look slammed but one will bottom out earlier depending on the combo of spring rates and/or shock valving as well.
Correct on 666 fab for the skid plates.
///Motorsport
Slammed Look?
« Reply #9 on: July 17, 2006, 05:13:37 PM »
wait so what are you saying? i got confused... with my H&R Races, i'm only going to go super fast on roads that i know, i doubt it'll take much to hit the pan as this height..
