Author Topic: are there any diff's between a US SPEC E30 325 gauge cluster and a US SPEC E30 318?  (Read 2300 times)
Cobra Jet
I am just curious, are there are differences between the E30 325 gauge clusters and the E30 318 gauge clusters?
The fuel and coolant gauges are exactly the same, right?
Are the speedo heads the same?
How about the Tachometer head, are those different?
What about the SI board or multiple circuit layouts of the entire cluster?
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
EN318isPDX
I know the red lines are different.
Jimmy Lewis
I believe that the VDO's and the Moto's are the same, besides the coding plugs between the 6 and 4 cars. Don't quote me, but I have a 325i cluster in my car, and only swapped the coding plug and everything works as it should. That is not to say that the boards and such are exactly the same, that I do not know.
1999 Estoril M3
1991 Brilliantrot 318iS
(for sale)
xwill112x
the mph and rpm will be diffrent..but it should hook up?
i had a white faced set of gauges from a 325 and they work..but not right..
Ich liebe meinen E30
Jimmy Lewis
If you are using the coding plug from your old M42 cluster then they should read correctly.
1999 Estoril M3
(for sale)
