Author Topic: Upper pan gasket  (Read 2705 times)
KenC
Upper pan gasket
« on: October 18, 2008, 09:00:22 AM »
Is it possible to change the upper pan gasket without raising the engine or dropping the steering rack?
KenC
Upper pan gasket
« Reply #1 on: October 20, 2008, 05:38:38 PM »
bump
Upper pan gasket
« Reply #2 on: October 20, 2008, 06:11:57 PM »
i don't think its possible without raising the motor but i think you can pull it off without removing the steering rack.
i was able to remove my e34 m50 oil pan without removing the steering rack, it was a bloody bitch but you can do it.
i put a jack right under the tranny just before it touches the oil pan and raised up. i also used one more jack under the header to give me that extra inch to finally pull it out.
my question is, whats holding you back from raising the motor?
EN318isPDX
Upper pan gasket
« Reply #3 on: October 20, 2008, 06:22:33 PM »
Ken I would just use a cherrypicker to lift the motor up. Thats how i plan to do my gasket. Let me know, i have a cherrypicker out in hillsboro if you want to use it
KenC
Upper pan gasket
« Reply #4 on: October 20, 2008, 06:41:19 PM »
I was just trying to gauge how long it would take me to do it.
I'm going to do it on a lift, so I'll probably just us a deadman jack or two to raise it up.
twright
Upper pan gasket
« Reply #5 on: October 20, 2008, 06:49:01 PM »
I am going to change my upper pan gasket tomorrow.  I'll let you know how long it takes.  I'm hoping to get it done in a day, but no more than two days.
kenika65
Upper pan gasket
« Reply #6 on: October 20, 2008, 10:49:49 PM »
http://www.m42club.com/forums/showthread.php?t=6075
Took me 9hr with quite a few breaks in between and a lot of other stuff to do.
« Last Edit: October 20, 2008, 10:52:51 PM by kenika65 »
nicknikolovski
Upper pan gasket
« Reply #7 on: October 21, 2008, 03:21:19 AM »
For the oil pans do you guys use a sealer or actual gaskets?
kenika65
Upper pan gasket
« Reply #8 on: October 21, 2008, 09:36:19 AM »
gasket with no sealer.
