Author Topic: fault codes  (Read 41426 times)
kowalski
  • El\' Duder
fault codes
« on: March 10, 2006, 02:39:55 PM »
1211      DME Control Unit
1215      Air Mass Sensor
1216      Throttle Potentiometer
1218      Output Stage, Group 1
1219      Output Stage, Group 2
1221      Oxygen Sensor 1
1212      Oxygen Sensor 2
1222      Lambda Control 1
1213      Lambda Control 2
1223      Coolant Temperature Sensor
1224      Intake Air Temperature Sensor
1225      Knock Sensor 1
1226      Knock Sensor 2
1227      Knock Sensor 3
1228      Knock Sensor 4
1231      Battery Voltage/DME Main Relay
1232      Throttle Idle Switch
1233      Throttle Wide Open Throttle Switch
1234      Speedometer A Signal
1237      A/C Compressor Cut Off
1242      A/C Compressor
1243      Crankshaft Pulse Sensor
1244      Camshaft Sensor
1245      Intervention AEGS
1247      Ignition Secondary Monitor
1251      Fuel Injector 1 (or group 1)
1252      Fuel Injector 2 (or group 2)
1253      Fuel Injector 3
1254      Fuel Injector 4
1255      Fuel Injector 5
1256      Fuel Injector 6
1257      Fuel Injector 7
1258      Fuel Injector 8
1261      Fuel Pump Relay Control
1262      Idle Speed Actuator
1263      Purge Valve
1264      EGO Heater
1265      Fault Lamp (check engine light)
1266      VANOS
1267      Air Pump Relay Control
1271      Ignition Coil 1
1272      Ignition Coil 2
1273      Ignition Coil 3
1274      Ignition Coil 4
1275      Ignition Coil 5
1276      Ignition Coil 6
1277      Ignition Coil 7
1278      Ignition Coil 8
1281      Control Unit Memory Supply
1282      Fault Code Memory
1283      Fuel Injector Output Stage
1286      Knock Control Test Pulse
1444      No Fault Codes
Sale:
Fore Sale Thread
tondelayo
Thank you!
« Reply #1 on: October 22, 2010, 03:44:07 PM »
Thank you kindly for posting those; other lists left out the fault code my '91 318is was showing: 1234.
Best,
Tondelayo
