is there a crankcase vent valve for a 93 318i m42
Author Topic: is there a crankcase vent valve for a 93 318i m42  (Read 16220 times)
Young Pete
« on: October 10, 2008, 05:52:58 AM »
from the bentley manual, the m44 has it underneath the intake manifold but for some reason they do not have it for the m42 or im just not finding it....
any 92-95 m42 owners wanna chime in..
(sorry i meant to say crankcase vent valve)
please only knowledgeable m42 owners.....:)
does the m42 even have a cvv valve or pcv valve?
location of valve and or pic would be wonderful
thanx.
JP 91iS
« Reply #1 on: October 10, 2008, 10:28:22 PM »
A quick browse on realoem.com turned up the following info (its part #11 in the drawing):
Part 11157501567 (CRANK CASE VENT VALVE) was found on the following E36 vehicles:
E36 318i CONVERTIBLE, M42, AUTO (BK63) : CYLINDER HEAD COVER
E36 318i CONVERTIBLE, M42, MANUAL (BK53) : CYLINDER HEAD COVER
E36 318i SEDAN, M42, AUTO (CA63) : CYLINDER HEAD COVER
E36 318i SEDAN, M42, AUTO (CC83) : CYLINDER HEAD COVER
E36 318i SEDAN, M42, MANUAL (CA53) : CYLINDER HEAD COVER
E36 318i SEDAN, M42, MANUAL (CC73) : CYLINDER HEAD COVER
E36 318is COUPE, M42, AUTO (BE63) : CYLINDER HEAD COVER
E36 318is COUPE, M42, MANUAL (BE53) : CYLINDER HEAD COVER
E36 318ti COMPACT, M42, AUTO (CG63) : CYLINDER HEAD COVER
E36 318ti COMPACT, M42, MANUAL (CG53) : CYLINDER HEAD COVER
(also same part number on following M44s:
E36 318i CONVERTIBLE, M44, AUTO (BH83) : CYLINDER HEAD COVER
E36 318i CONVERTIBLE, M44, MANUAL (BH73) : CYLINDER HEAD COVER
E36 318i SEDAN, M44, AUTO (CC03) : CYLINDER HEAD COVER
E36 318i SEDAN, M44, AUTO (CD83) : CYLINDER HEAD COVER
E36 318i SEDAN, M44, MANUAL (CD73) : CYLINDER HEAD COVER
E36 318i SEDAN, M44, MANUAL (CC93) : CYLINDER HEAD COVER
E36 318is COUPE, M44, AUTO (BE83) : CYLINDER HEAD COVER
E36 318is COUPE, M44, MANUAL (BE73) : CYLINDER HEAD COVER
E36 318ti COMPACT, M44, AUTO (CG83) : CYLINDER HEAD COVER
E36 318ti COMPACT, M44, MANUAL (CG73) : CYLINDER HEAD COVER)
-JP
Project M42: generating funds
Young Pete
« Reply #2 on: October 11, 2008, 12:45:20 AM »
Quote from: JP 91iS;58260
well i can't find the damn thing.  if any1 helps me find it or gives an actual photo location on a m42 i will buy them a 6 pack of beer..
nuvolarossa
« Reply #3 on: October 11, 2008, 12:55:08 AM »
you don't have it... there is another diagram for 1993 318i, or for cars before 1/1994 :) That valve was fitted from 1/1994. In your car the hose from the valve cover go straight to a fitting in the throttle body, without valves in the middle.
Young Pete
« Reply #4 on: October 11, 2008, 02:41:27 AM »
Quote from: nuvolarossa;58268
thank you very much...now i know my rough idle is not due to the crankcase vent valve/pcv valve.
nuvolarossa
« Reply #5 on: October 11, 2008, 07:35:20 AM »
check if the hose that is on the side of valve cover (the part on very top of the engine, the one with the brand ====BMW=== ;)) go straight to the throttle body to be 100% sure :)
(there should be a fitting under the throttle body)
« Reply #6 on: October 11, 2008, 11:16:27 AM »
btw fixed your title for ya ;)
Young Pete
« Reply #7 on: October 11, 2008, 02:13:05 PM »
Quote from: nuvolarossa;58274
yes the hose on top of the valve cover goes straight to the throttle body no crankcase valve underneath.
nuvolarossa
« Reply #8 on: October 11, 2008, 03:14:41 PM »
so I was right! :D now go ahead to find what's causing that bad idle ;)
