Author Topic: New 318is failed idle smog test  (Read 1854 times)
AndeeG
« on: October 03, 2008, 07:50:53 PM »
A few weeks ago, I picked up sumyungguy's 318is, which has been great so far. Initially he thought that it had been smogged recenty enough that I wouldn't have to do anything, but it turned out the purchase was just a few days after the 90 day smog cutoff. I registered the car at the DMV, but they insisted that I get a new smog certificate.
I finally got around to getting it smogged again today and the car failed the idle test, but passed the 2500rpm test at only 11ppm (the max allowed is 140). The car has an intermittently surging idle that apparently has been an elusive problem to solve. About half the time, it idles smoothly at 800-900rpm just like it should. The other half, it'll surge up to about 1200 or 1300, then immediately drop back down to maybe 700 or so - just enough to feel rough for a moment - then immediately surged back up 1200 or 1300.
Would you think that the smog failure was due to the idle issue or could it be something else? And what could be the underlying cuase of the idle problem?
