Do you think its worth the 1k? Did you ask them to paint it normal black? Where did you buy that samco boot?
Hi Sheldon,
Is it worth the money? That's always a relative term. It's worth it if you are willing to spend/experiment with the potential of being disappointed. By itself (if my car was completely stock), I would probably say "no" to buying it. It is one of those items that incrementally adds up with all the other small tweaks. :rolleyes:
Yes, I did ask MM to paint the manifold semi-gloss black, like my cam cover.
The Samco boot was ordered through
sporthoses.com (who happen to be local to me and great people to work with) for $113.14 -- nearly 3x the cost of the OEM unit. If you've looked inside the OEM unit, there is a lot going on in that boot: texture, accordion bends, etc. The Samco boot is simply smooth inside -- much better airflow. The Samco boot is actually for the E36 M42 engine, so it's bend is ever-so-slightly different than the E30 M42 OEM boot (the Samco boot doesn't bend down as much as the OEM E30 boot). It was a custom order, as they had none in stock and it took about 1 month to get it made in the UK, as Samco makes these products by hand.
BTW Nivola, where do those covers for the shock mount nuts come from - looks nice and clean.
Hi Larry,
Interestingly, the shock mount nuts came with the car when I bought it from the previous owner. Just a bit of rubber/plastic cleaner and they look as they do.
