i just finished putting new sprockets, chain, rails, tensioner, gaskets and all seals in the m42 i just picked up(175k miles). go to put the flywheel on and hear a "thunk" when i push the FW down. take off the FW, andgrab the crank pully and push/pull off the timing case and my crank is thrusting in-out a good 1/32" or more. :mad:
so, as need a car to drive ASAP and just got everything done and almost back in the car, im gonna run it gently for a few weeks till i get my other car back in order, with some Lucas oil additive. then either find a low milage block or try to change the thrust bearing or all the crank bearings.
questions are:
Has anyone changed the thrust bearing without dissasembling the motor?
like leaving the rods bolted on the crank, take off the chain, remove the main caps and drop the whole crank an few inches, pulling the pistons to the bottom of the cyls? and maybe swapping in a new thrust(360*)bearing?
Or must i take it all apart and rebuild a block while im there??
if so id probly do some Eagle rods and maybe stock pistons w/ a low C/R MLS gasket and ARPs.
Any thoughts or advice?
TIA
