Author Topic: need help with fuel issues  (Read 4445 times)
eric16v
« on: September 19, 2008, 11:12:47 PM »
i ve recently been having problems with my 318is stalling out on me. I will be driving along with no issues when i feel the car hicup or bog down on me as if i had run out of gas. i thought it was the fuel pump because the engine is cranking but wont actually start. but then after a while the car can be started and drivin as if nothing ever happened. usually when the pump goes out it s out. or? when i got home i diconnected the line after the filter and cranked it and fuel was flowing at a pretty good rate. so i put everything back together and started it up. it ran good for about 5 mins. but then it dies from lack of fuel. any one have any ideas? also where is the pressure regulator located?
Thanks in advance.
AcSchnitzer318is
« Reply #1 on: September 20, 2008, 12:09:05 AM »
fuel pressure regulator is under the upper intake manifold on the front of the fuel rail.  Sorry can't help you with the rest of your problem.  This happened to a buddy and we traced it to an electrical break just underneath the bottom seat at the pump.  Might want to pull your seat and check your wires...
strad
« Reply #2 on: September 20, 2008, 05:15:39 PM »
Check relays as well.  They are under the wiring loom cover that runs across the firewall behind the intake manifold.
eric16v
« Reply #3 on: September 21, 2008, 01:34:29 AM »
The relays on the driver side right? I believe there are two big orange ones. do you know which is for the fuel pump? and how do you test them?
strad
« Reply #4 on: September 21, 2008, 03:15:54 PM »
Not in the fuse box.  Under that black plastic wiring cover in the center, between the manifold and firewall.  I can't remember what color they all are.  The main relay on mine was white though, and the other two are exactly the same as one another.  I haven't actually had to test them, so am not the expert there, but what you can do is clean the contacts -- that should solve any intermittent electricity problems.
eric16v
« Reply #5 on: September 22, 2008, 12:22:04 PM »
i checked my CPS and i found the resistance between term. i and 2 is at 501 ohms. people on the forum said it should be at 650 ohms +/- 10%. is this in range? im not sure but i think its out. any suggestions?
mmkale
Re: need help with fuel issues
« Reply #6 on: February 07, 2019, 09:44:40 AM »
i had the same prob once. it was the fuel pump itself. apparently, after the fuel pump runs for a bit the shaft gets stuck. let it sit for a good while and it'll run again, sometimes for hours.
eric16v
« Reply #7 on: March 09, 2019, 11:09:01 AM »
Ended up changing the cam position sensor and having the AFM rebuilt. Seemed to solve the issues.
