Author Topic: m42 PCV at the Manifold  (Read 4691 times)
bearsbmw
« on: September 10, 2008, 11:18:42 PM »
I can't think of anything to plug that spot with on the manifold ... any idea's anyone?
kowalski
  • El\' Duder
« Reply #1 on: September 11, 2008, 01:13:37 AM »
what spot in particular?
you can buy caps that will fit, available at any auto parts store
or you could put a small piece of hose on, with a bolt in one end hose clamped on
 or you could tap the hole and put a bolt in it.
Sale:
Fore Sale Thread
nuvolarossa
« Reply #2 on: September 11, 2008, 02:22:42 AM »
Quote from: kowalski;56501
+1, the poor man solution that works great, cheap and easy ;)
adam12hicks
« Reply #3 on: September 11, 2008, 10:20:17 AM »
What's the benefit of plugging it?
2005 X5 3.0 (kid hauler)
bearsbmw
« Reply #4 on: September 11, 2008, 06:19:06 PM »
I mean blowing your engine up when Boosting 12psi in the PCV Line is not good lol
« Last Edit: September 11, 2008, 07:41:00 PM by bearsbmw »
« Reply #5 on: September 11, 2008, 07:36:15 PM »
Quote from: bearsbmw;56534
blowing your engine up lol among other thing's...
What do you do about crankcase ventilation?
bearsbmw
« Reply #6 on: September 11, 2008, 07:39:30 PM »
catch can with a breather filter
nuvolarossa
« Reply #7 on: September 12, 2008, 05:19:38 AM »
bears, I see that you have a M42... :D
I bought a used M42 inlet manifold, but the owner sent it without the PCV... manifold can't be used without because the upper part of it will hurt the fuel line.
So I'm building a spacer to retain the stock height. Can you measure how much is thick the PCV where upper and lower parts of the manifold join together?
This will save me time if you're able to do it. Otherwise I need to do a "trial and error"...
bearsbmw
« Reply #8 on: September 12, 2008, 08:32:50 AM »
will do .. get back to you soon
nuvolarossa
« Reply #9 on: September 12, 2008, 08:43:04 AM »
do it when you want, it's not a urgent problem ;)
bearsbmw
« Reply #10 on: September 13, 2008, 11:45:22 PM »
you just want thethickness of that spacer between the upper intake and lower intake correct?
nuvolarossa
« Reply #11 on: September 14, 2008, 02:03:33 AM »
Quote from: bearsbmw;56660
Yes, only that!:)
