Author Topic: M42 Oil Feed & Spark Plugs  (Read 5269 times)
bearsbmw
« on: September 09, 2008, 03:35:42 PM »
Anybody know the size of the NPT at the oil presure switch for the m42?
What cold spark plugs should I run in the m42 while under boost? Part #?
Thanks
nuvolarossa
« Reply #1 on: September 09, 2008, 04:57:19 PM »
Quote from: bearsbmw;56403
Thanks
It's a metric fitting, M12x1,5mm. The oil sensor is the same between 4 and 6 cyls BMW, so a fitting for a 6 cyl will have the same thread. ;)
halcron
« Reply #2 on: September 09, 2008, 08:13:35 PM »
For plugs you could try NGK (get heat range 7-8) or Denso (IK22) or even Bosch. Brisk (is also good but is on the expensive side. Another brand thats popular and quite good is volker.
e36mike
« Reply #3 on: September 10, 2008, 12:20:13 AM »
im also having mine done so i can get the t-piece sorted is there no other place on the engine you can tap into to get oil pressure to the turbo?:confused:
i was thinkin of drilling a hole on the side of the block where the oil gallery runs so that the pipe is shorter to the turbo:rolleyes:
am i being crazy ??:eek:
bearsbmw
« Reply #4 on: September 10, 2008, 01:59:16 PM »
I have decided that Im just going to 1/8 tap the filter housing cap and go from there... it will be unfiltered but I don't see it being a hudge problem because if you have big chunks of anything in your motor you have a major problem anyway
e36mike
« Reply #5 on: September 10, 2008, 03:09:12 PM »
i think ive see it done like that on the web somewhere
i cant see why it should be a problem
you right if you have big chunks of anything in your engine you have bigger problems than infiltered oil:D
vagrant_mugen
« Reply #6 on: September 10, 2008, 04:08:12 PM »
i have been wondering the best oil feed tap spot too.  might tryin tap the filter housing, but i wanted to leave that be so i could tap into it for an oil cooler later on.
bearsbmw
« Reply #7 on: September 10, 2008, 04:39:03 PM »
this is what you will need if you want to tap into lower housing at the presure switch... I tryed every shop in ottawa that sells fitings and nobody could pull one up for me
http://www.turbowholesale.com/catalog/Autometer-Adapters--Fittings-Metric-Adapters-Electric-Temperatu-p-9566.html
Boosted E30
« Reply #8 on: September 10, 2008, 07:37:03 PM »
just take a banjo bolt and the fitting thats the proper thread for the hole where the oil pressure switch goes drill a hole in the top of the bolt and tap it for the oil pressure switch go to a place that makes power steering line and that stuff get them to put the banjo fitting on the hose and what ever other fittings you need and your set. this is what i did it looks pretty clean and works well.
bearsbmw
« Reply #9 on: September 10, 2008, 08:30:25 PM »
ya it's m12 and it's almost impossibe to find where I live
nuvolarossa
« Reply #10 on: September 11, 2008, 02:21:53 AM »
when I was gathering parts I was in the same pboat, because all parts bought from USA had imperial threads and here we use only metric, so I bought another order of fittings from USA  :D pricey but it works ;)
