Reassembled Engine - Won't run now
Author Topic: Reassembled Engine - Won't run now  (Read 5027 times)
KenC
« on: September 09, 2008, 05:11:21 AM »
So I put a new block from an E36 M42 into my e30 and swapped everything else over to it from my E30 engine, but now that everything is back together, it doesn't want to run upon start up.
Yes, timing is perfect.  I'm getting spark and fuel.  It will sputter a bit when the starter is going, but will immediately die after that.
I think I may have hooked some of the electronics back up incorrectly.  Is there some sort of visual depiction of the wiring harness and how it hooks to both the engine and the power distributer block?  Where is the fusible link in the e30 318is?
hesgone2fast
« Reply #1 on: September 09, 2008, 09:02:38 AM »
Make sure you connected the crank and camshaft sensors in the correct place, if you don´t know, just switch them and try. check the coils for the correct position, and maybe the throttle sensor..., AFM is OK?
I assume you have the crank in the correct position with the cams (not 180º around) If not, the timing would be OK, but the crank sensor would not read properly (it would read with a 180º error).
Having all this in order, it should run. or at least start...
Good luck!
nickmpower
« Reply #2 on: September 09, 2008, 09:22:51 AM »
fuck im about to do this same thing, i pick the engine up tomorrow and i have to leave for school in like a week! you make me nervous.
if the fusable like was bad you wouldnt be getting spark or fuel. coils, cams, and crank sensors are a great place to start, do you know if the injectors are firing? if your cam gears arent i the right place that would give you problems even if your timing is right.
KenC
« Reply #3 on: September 09, 2008, 10:18:56 AM »
I'm 100% confident that the timing is spot on, the injectors are firing, and I have spark.  Whether or not the spark is timed properly is another issue.
1. My temp gauge shoots all the way to max when I turn the key.  I think it may be hooked up incorrectly.  It's the white one with two wires that plugs into the front portion of the head, no?
2.  I checked the resistance of the crank position sensor, and according to the multimeter, it was about half the resistance of what the Bentley says is good (500 ohms or so).  I checked an M20 that was laying around and got the exact same reading.  This made me a little suspect of the multimeter.  Does anyone know what the spec resistance of an M20 CPS is supposed to be?
3.  I suppose I should check the cam sensor as well.  Does anyone know the correct reistance?
nickmpower
« Reply #4 on: September 09, 2008, 07:23:03 PM »
you need to switch one of the coolant sensors from your old head. theres one that only has one wire
KenC
« Reply #5 on: September 10, 2008, 12:33:07 AM »
Crossing my fingers my crankshaft isn't 360 out.
KenC
« Reply #6 on: September 10, 2008, 12:33:57 AM »
Quote from: hesgone2fast;56370
Where can this "180º error" be read?
hesgone2fast
« Reply #7 on: September 10, 2008, 02:31:14 AM »
Quote from: KenCopperwheat;56429
Well, I´ve ben thking this over and it wouldn´t matter if the crank was 360º over(which is what I meant), it would read the same position. Sorry I was confused...
as long as cyl1 is on tdc, and cams are pointing up on cyl1, your timing is OK.
I think your problem is that you have the cam and crank sensors plugged in backwards.
About the temp gauge reading that, the sensor might be ok, but you could have plugged the water temp switch on the oil pressure sensor. this happened to me. it sucks b/c it´s hard to get to it under the manifold...
Keep us informed!
KenC
« Reply #8 on: September 10, 2008, 08:09:46 AM »
Ummm.... the valve pockets aren't symmetrical.  If the crank is 360 out, the valves are toast upon first start up.
Cam and crank sensors are plugged in the correct spots.
Would the temp sensors in the wrong spots keep the engine from starting up?
colin86325
« Reply #9 on: September 10, 2008, 10:18:20 AM »
Make sure the fuel lines are connected properly.  They're easy to mix up.
KenC
« Reply #10 on: September 10, 2008, 12:08:15 PM »
Quote from: colin86325;56446
well the plugs are wet when I pull them.  Wouldn't that indicate that they're hooked up properly?  I know what you mean by mixing them up though... the two are close to eachother.
nickmpower
« Reply #11 on: September 10, 2008, 04:21:35 PM »
what all did you change on the e36 engine?
EN318isPDX
« Reply #12 on: September 10, 2008, 05:16:52 PM »
Have you checked all your grounds so make sure they are all connected?
KenC
« Reply #13 on: September 10, 2008, 05:19:25 PM »
Quote from: nickmpower;56468
The only thing I used from the e36 was the block.  Everything else is from my original e30 engine.
Oh, and I guess my cam gears were 180degrees off.  I put #4 at TDC placement instead of #1 :-/
nickmpower
« Reply #14 on: September 10, 2008, 08:02:00 PM »
well i just picked my my engine, took the VC off and the cams were rusty and one of them was about 1/4 turn off from where it should be. back on the trailer it went
i was going to offer to help you figure it out since i no longer will be busy with my car, but it looks like you have it figured out
