Author Topic: 60mm - 40 mm drop in ride hight  (Read 3159 times)
no1_jazz
« on: September 08, 2008, 07:27:32 AM »
hi there guys  has any one got this suspenssion set up
front 60mm rear 40mm if so could you please post pictures
also what suspension kit do you guys have
many thanks
JAZZ
Vladi
    • http://www.bmwzone.ro/forum
« Reply #1 on: September 08, 2008, 01:28:32 PM »
Look at my profile topic and see what a 80-40 drop looks like. :D
no1_jazz
« Reply #2 on: September 08, 2008, 02:28:35 PM »
profile topic hmm... do you have a link i can directly access but im sure it looks the dogs dangles lol
the one in your sig pic looks nuts as well
is that the 1?
having it to low at the rear end ....i mean dont you get negative camber which results in poor handling an uneven excessive tyre wear?
hows the handling on it and can you get peoplein the back seats?
also what kit do youhave bilstine...???
no1_jazz
« Reply #3 on: September 09, 2008, 11:15:45 AM »
anybody
Spec 2
    • http://www.pnwriders.com
« Reply #4 on: November 14, 2008, 02:39:19 PM »
That's way too low unless you're tracking primarily and have perfect streets around.  You're going to bust an oil pan or three regardless. No way you'll be able to hold more than 1 passenger at any time.
I'm dropped 43mm front and 33mm rear.  My 17" wheels tuck in the back and front has about 0 space between top of tire and fender. I struggle to carry two people in my car and bottom out easily doing so.  You will also get yourself a decent amount of neg camber, both front and rear.  Handling will be fantastic (read: on rails) but again, I personally wouldn't go lower then 40-50mm front and about 30-35mm rear.
