DISCUSSION
General Topics
2 Questions
Topic: 2 Questions (Read 2780 times)
318iEnthusiast
2 Questions
June 03, 2006, 01:07:11 PM »
Ok ...
1) Where is the thermostat, and how do I get to it?
2) Why won't my AC fan turn on?
Thanks!
Former *********
Legendary
June 03, 2006, 01:49:27 PM »
http://realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=11_0559&hg=11&fg=35
A/C fan could be resistor. It's accessed under the hood behind the bolt on panel that goes across the firewall. It's under the windshield wiper/air inlet area. It's the same panel you remove to get at the blower motor. A Bentley repair manual comes in handy. If it doesn't work on the A/C but does on the heater, that usually indicates low freon. If you mean the A/C fan in front of the condensor, there's also a resistor on the motor bracket.
Last Edit: June 03, 2006, 01:51:45 PM by D. Clay
shellback
2 Questions
June 03, 2006, 04:08:59 PM »
I had the same issue with my aux fan - also used for the a/c.
http://www.realoem.com/bmw/showparts.do?model=AJ93&mospid=47318&btnr=64_0516&hg=64&fg=55
I replaced the resistor (part # 5) and the problem was corrected.
Hope this helps,
Chris
318iEnthusiast
2 Questions
June 03, 2006, 05:05:03 PM »
is there a fuse that powers it? if so which fuse # is it?
Zoso
Sr. Member
2 Questions
June 03, 2006, 08:00:06 PM »
http://zoso.no-ip.org/318i-thermostat.html
Mike -
E30 1991 318i - 318i Tech Procedures
E36 1998 M3 Coupe - M3 Tech Procedures
[IMG]http://zoso.no-ip.org/images/Sig
DISCUSSION
General Topics
2 Questions
