When I replaced the profile gasket, I did a complete valve job. Also did a little port and polish job. Also advanced the intake cam about 2 degrees. New plugs, deleted the mess under the intake, Checked the tightened the oil pump. New oil and filter with 10w - 30. Changed all fluids to redline or the best I could get. Car has new front end (stock), drive shaft dampener, shocks/struts, front lip, Also replaced the gravel shield and belts, hoses, timing chain, gears, guides, etc., windshield and seals. New paint and all outside trim, badges, etc. Balanced each wheel dynamically. Tires are Hankook touring. Car had 107k on it.
