Author Topic: Twins from a M47N on ebay.de...  (Read 2596 times)
nuvolarossa
« on: August 25, 2008, 07:40:02 AM »
Unfortunately it's not time for me to open the engine... but maybe someone brave enough can try to modify them to fit...
ITEM #1
http://cgi.ebay.de/BMW-320D-520D-E46-E39-110KW-150PS-KURBELWELLE-204D4_W0QQitemZ250285321752QQcmdZViewItem?_trksid=p3286.m20.l1116
ITEM #2
http://cgi.ebay.de/BMW-320D-520D-E46-E39-110KW-150PS-KURBELWELLE-204D4_W0QQitemZ300252128828QQcmdZViewItem?_trksid=p3286.m20.l1116
both are from M47N
DISCLAIMER: I don't know what they exactly need to fit...
Boyracer
    • http://www.jannousianen.net
« Reply #1 on: August 25, 2008, 10:38:00 AM »
Yeah I have had them on under surveillance for few days and thought about posting them here :)
Problem is that they are from newer engine that has balancer shafts, hence the gear in the flywheel end. And if you compare those to M42/M47 early crankshaft, you will see these two have shorter front "noses" which I think need extending which in turn means costs and also it is not-so-great for high rev reliability.
Cheap they are but not direct fit to our purposes I'm afraid :(
