Yes you'll need this little baby
Sounds like you got your cams about right, although I'd suggest you try and turn the intake cam slightly CW (seen from front of engine) and exhaust slightly CCW. Exact position will have to be found in dyno but this will give you a start.
I also suggest you change that DP before changing turbine etc, 2 1/4" is way too small and will affect your spool and if your backpressure is too high you'll have problems with controlling the boost aswell.
Remove the hood and exhaust and just put one 90 deg 3" bend straight up and go for a ride, quick and easy
