Author Topic: Buildup: My quest for NA 280 hp  (Read 156710 times)
Boyracer
    • http://www.jannousianen.net
« Reply #180 on: July 23, 2012, 03:33:12 AM »
Well well well, it seems that I got the engine running with mega :eek:
http://www.youtube.com/watch?v=BAmidb0XWdw
Friend is handling the throttle :)
Engine started pretty easily in the end, after I fixed some problems liek crossed fuel lines and ICV that fed 6 volts to ingition wire preventing car electricts to shut off and causing mega to reset after few seconds of cranking.
Engine runs now but no tuning has been done yet. Must source shorter alternator belt and suitable connector for that Nippon Denso alternator.
Alternator setup:
EGT sensors:
Front brakes are finally getting ready to install too...
enildeR
  • lol ur face
« Reply #181 on: July 24, 2012, 10:45:15 AM »
what brakes are you putting on? the rx7 ones?
Boyracer
« Reply #182 on: July 25, 2012, 02:32:57 AM »
Quote from: enildeR;113918
Wilwood Superlites:
E36-italia
  • -Receive: 6
    • Motorsport-Media-Design.com
« Reply #183 on: July 26, 2012, 12:50:01 PM »
Did you made a bracket to mount the alternator on the airco mountings? (or did you drilled a hole in the engine :P )
Boyracer
« Reply #184 on: August 20, 2012, 08:05:40 AM »
Some progress:
http://www.youtube.com/watch?v=ANy7pwd6MM0
Small Nippon Denso alternator from Toyota Yaris charges the battery as it should. Vacuum rail is finished. Alu header tank has been installed etc. Basically car now moves again on it's own power, too bad it has not passed road inspection lately :p
I need to make some basic tuning on the road before going to dyno to tune igntion map. Also I need to find out if the car holds together in general, lots of changes...
Engine load is now MAP based but that should ideally be switched to ITB load mode before dyno but I don't have enough data to use it yet. I hope to install Shrick copy camshafts soon too.
italstac
Throttle body adapter
« Reply #185 on: August 31, 2012, 12:53:50 PM »
Quote from: Boyracer;113251
Car is back on it's feet but not yet running, need bit of vacuum hose, modification to DIY vacuum rail and then I can test if engine starts with megasquirt.
Hello, I'm also installing a throttle body in a m3 engine M42. How did you adapt the throttle body? There are adapters or something you've created. I'm installing a control unit Megasquirt PNP. Which performance did you get? Forgive me if my English is not correct, I'm Italian!
ToniBmwPortugal
« Reply #186 on: November 04, 2012, 06:17:19 AM »
Hi there!
I watch this project with great interest, i think its one of the best projects of the M42 around here! Congratulations.
I few pages back there was a search for bigger intake valves that could fit the M42 engine.
According to supertech valves:
BMW M42 intake Valves:
Head Diam    Stem Diam    Length
33mm                5,97mm          106.10mm
And i have found the Peugeot  EW10J4S intake valves to be the exact same dimensions but off course larger in diameter:
35mm                5,97mm          106.10mm
Look here:
http://www.supertechperformance.com/ivalves.html?id=1
http://www.supertechperformance.com/ivalves.html?id=12
Is it possible to make it work?
Congrats on the build and keep on going!
romkasponka
« Reply #187 on: November 04, 2012, 09:50:07 AM »
It should work. Also it depends from Valve collet where it is.
E30 318is M42
E36 318is M44
pvl 318is
« Reply #188 on: March 09, 2013, 08:57:54 AM »
what happend to this build?
i used to check up on this one (and his previous one) regularly. amazing builds!
Nicolai-Denmark
  • BMW E36 318is Coupe individual
Re: Buildup: My quest for NA 280 hp
« Reply #189 on: June 06, 2014, 05:39:13 PM »
So did he make his 280hk mark or what?
Boyracer
« Reply #190 on: December 27, 2014, 02:49:05 PM »
Not yet :)
Finally 1.5 years ago I bought a house with space for workshop and garage so I could work on the car.
I also bought another identical 318is Class II:
Original project is being stripped bare to be ready for roll cage, pedal box and completely new electrics:
On top of that, I got an offer to work on norway which I accepted... Now I have money and room to build car but no time apart from vacations  :o
keflaman
  • -Receive: 35
« Reply #191 on: December 27, 2014, 05:13:31 PM »
Welcome back! :D
What exactly is a class II?
E36-italia
  • -Receive: 6
« Reply #192 on: December 28, 2014, 08:02:29 AM »
homologation specials.. quite a rare car i believe...
Tgoode318
  • -Receive: 11
« Reply #193 on: December 30, 2014, 10:47:53 PM »
I like your "werkstatt" sign it adds a nice touch to the garage :)
« Last Edit: December 30, 2014, 10:51:38 PM by Tgoode318 »
-'94/05 M42 Convertible
-2001 330CI M Package
-2016 M4 Competition
Darky
  • -Receive: 23
« Reply #194 on: December 31, 2014, 03:43:03 AM »
Excellent
Glad to see this continue!
Cheers rohan
