MM reached those values in a S14 with 13,5:1 CR, but that has 37mm inlet valves and 33 exhaust... 35mm is really the maximum for intake valve in our M4x?
S14 had far bigger bore then M42/S42 so it could also accomodate bigger valves too. Here's some S42 data (I have posted these earlier):
S42 had 35 mm inlet / 32 mm outlet valves.
280 hp from 2,05 liters is veeeery challenging task (and right now I am missing the crankshaft to give me even that displacement). If I don't get the crankshaft I must be very happy with 220-240 hp.
The guy from who I bought the forged pistons developed S50B30 to give 375 hp (around 120 hp/ liter) with reworked head, larger valves etc. If I could reach same level of tune I would still be at 240-250 hp range. BUT! He only revved the engine to 7500 (peak power was at 7000) and I hope to have some 1000 rpm more in use which always helps. The problem is to get enough flow from the cylinder head to support such revs.
I think 8500 rpm is reachable with good quality parts and careful planning and assembly. The areas that I am more worried about are cylinder head cooling and bottom end lubrication. S42 had modified cooling system which had 4 coolant in or out ports on cylinder head connected by metal pipe just below intake port. How can you replicate that? Also, what kind of modifications bottom end needs to sustain high revs reliable? New oilways on crankshaft, oil squirters on block walls? Lots of questions!
I need to split this to smaller tasks, if I wait until everything is ready it will be a long time before the engine runs! So I have thought about plan like this:
Fall/winter 2008:
1. ITB's ready (adapter plate started already, need airbox etc)
2. Megasquirt engine control ready
Those I can already use and test with my current engine to see how they work.
Spring/summer 2009
3. Bottom end (forged pistons, block boring, new con rods, M47 crankshaft if possible, general overhaul)
4. Clutch (lightened stock flywheel and stock clutch or custom flywheel and multiplate clutch)
I can use this new bottom end with stock head I have now with ITB's and Mega.
God knows when?!?!?!
5. Cylinder head (bigger valves, porting, long duration cams, stiffer springs, new guides etc etc etc).
This is simply the most important and expensive bit of all and it must be just right :eek:
