That sounds right for a test with 10 turns of the starter, the numbers are high and very close. You seem to have a very healthy engine with close to no blow-by. I don't think compression ratio effects the outcome of a compression test, it measures how tight the tolerances are between the rings and cylinder walls rather than the ratio. Though, with numbers that good on such an old motor it is possible it has seen a rebuild.
