Author Topic: Increase air to the radiator  (Read 2201 times)
nomad
« on: August 07, 2008, 08:14:14 PM »
So when it's over 100*F and I'm driving around I need all the cooling effect I can get. I've just installed an electric fan and made sure the cooling system is all refurbed after my overheating incident a year ago.
So I'm looking at the front end of the 318 and wondering why they bothered to block out the bottom most valence vent. Cost savings I suppose.
I like the way the oil cooler adds visual detail to the 325 so I jumped on one at the junkyard. Installed it today.
There is a plastic tray that helps direct air from only the top vent into the radiator area. It bent down easily to direct flow from the bottom vent as well.
So now i have two times as much vent air being directed to the radiator.
Small but, every bit of extra air and cooling helps.
« Last Edit: August 07, 2008, 11:02:44 PM by nomad »
SoCal, 318is: IT RUNS AGAIN!
Cobra Jet
« Reply #1 on: August 11, 2008, 12:01:36 PM »
Do you have a better pic of the "slotted" vent you added that is in that above picture?  What is the BMW part # for that piece, any idea?
Also, from the pic you posted, I'm not seeing the plastic tray or "diverter" you are referring to, any other pics of that part or piece?
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
xwill112x
« Reply #2 on: August 11, 2008, 06:59:59 PM »
yea i have one of those also..i didnt notice anything...but it sure does look alot better.
Ich liebe meinen E30
