Author Topic: m3 tach cluster will it fit??  (Read 2466 times)
dwf08
« on: August 02, 2008, 10:10:51 PM »
sry if this sounds dumb but will the cluster fit in and plug up and work in my 91 318is??
Jimmy Lewis
« Reply #1 on: August 02, 2008, 10:52:01 PM »
I've read over at r3v that the cluster will indeed swap over just fine, but that neither the m42 nor the m20 coding plugs will make the cluster scale correctly. As in if you rev to 7K it will actually read 8K, so unless you just like to pretend that your car revs to 8K then there really isn't any point. Elaborate on why you intend to use one, and we can point you in the right direction.
1999 Estoril M3
1991 Brilliantrot 318iS
(for sale)
dwf08
« Reply #2 on: August 02, 2008, 11:01:13 PM »
i like the way they look better than the one i have
Jimmy Lewis
« Reply #3 on: August 02, 2008, 11:15:54 PM »
Well in that case you can actually make the stock cluster look a lot like it by painting the needles red with model paint, obviously it wont have the ///m badge but it is what we get by owning m42 cars.
I know the pictures aren't the best but here are a few:
« Last Edit: August 02, 2008, 11:19:04 PM by Jimmy Lewis »
1999 Estoril M3
(for sale)
