Author Topic: Turn Signal?  (Read 2611 times)
Colo318IS
Turn Signal?
« on: July 31, 2008, 12:27:05 AM »
Havin a turn signal issue...right rear is out.  I have a right rear taillight and brake light, but no right rear turn signal. I have checked and replaced both the bulb and the fuse, still not working...just curious if there is anything else I should be checking?
Turn Signal?
« Reply #1 on: July 31, 2008, 10:50:49 AM »
Just the right rear turn signal, correct? You've swapped with a *known* good bulb?
Check the wiring harness, starting at the connector for the lamp holder that is clipped in the taillight housing itself.
Colo318IS
Turn Signal?
« Reply #2 on: August 04, 2008, 01:25:47 PM »
yes, it is just the right rear turn signal...the taillight, brake light, reverse and the front right turn signal all work.  Yes, I did swap it out with a "known" good bulb and fuse, but still not working.  I will check the warning harness..
Thank you,
Jay
Colo318IS
Turn Signal?
« Reply #3 on: August 18, 2008, 01:48:55 PM »
an update....
I did have a known good bulb and fuse so I knew that wasn't the issue.  It ended up being the connection on the wiring harness.  To test this I took out a known good bulb and placed the connections from the bulb against the corresponding positive & negative wires leading to the socket...the bulb lit right up.  I then took a flat head and just pushed in the wires at the socket  so it was making good contact.  problem solved.
