Author Topic: Turbo Build  (Read 3778 times)
narbar_1234
Turbo Build
« on: July 24, 2008, 02:35:58 PM »
Well as atlanta no longer make supercharger kits my car is now booked in the garage for a turbo, the turbo shall be running at 7psi and will have a uprated ecu and will be fully maped, what sort of power gains shall i expect?
vatos_p
Turbo Build
« Reply #1 on: July 25, 2008, 02:10:40 AM »
my car , in 7 psi , did 200hp ( stock internals - no compression drop )
steer with the rear !!!
narbar_1234
Turbo Build
« Reply #2 on: July 25, 2008, 06:53:58 AM »
thanks for your reply, what psi can our cars go up to with the standard compression?
Hodge
Turbo Build
« Reply #3 on: July 27, 2008, 09:55:23 PM »
Nice to know!
I am also looking to turbo my M42 one of these days....something low pressure (7-9psi).
1995 E36 318isc
BMABMW
Turbo Build
« Reply #4 on: July 28, 2008, 12:45:32 PM »
Quote from: narbar_1234;53794
I read in another thread it was something like 14 psi with a good tune
vatos_p
Turbo Build
« Reply #5 on: July 29, 2008, 01:31:21 AM »
i think 7 psi with all internals stock and no compression drop is the limit , with very very very good tune you can go to 10 - 11 psi , but thats it...
with compression drop and new forged pistons ( with compression lower ) you can go as much as you can... ( stil stock con rods and crank )
rob_e30
Turbo Build
« Reply #6 on: July 29, 2008, 08:25:36 AM »
What kind of ECU upgrade are you planning?  Something with integrated knock control is key.  I'm not sure I'd push 14psi with the stock CR.  I would keep it at 10 or below, but it won't really matter if you don't have the proper ECU and tune.
