Author Topic: Dash lights wont turn off!!!!!  (Read 3444 times)
gas axe
« on: July 15, 2008, 03:37:53 AM »
Hi there, I cannot turn my dash lights, number plate lights off. I've changed the headlight switch to no avail. This problem seems to have arisen after i installed an aftermarket radio. I have to remove a fuse to get them to go off.
 Can anybody shed some light on this?
Thanks
« Reply #1 on: July 15, 2008, 12:20:21 PM »
Sounds like you may have a problem at the new deck. Did you install it yourself, or pay someone to do it?
I would doublecheck the wiring for the aftermarket radio, make sure you properly wired it - in particular, the constant +12v (red/green to connector C215, then yellow to the OE radio) and dimmer (gray/red to connector C215, then white to the OE radio). Sounds like they are connected together to me. Is it fuse 21 you have to pull?
EN318isPDX
« Reply #2 on: July 15, 2008, 12:27:01 PM »
Quote from: ak96ss;53328
Sounds very book smart there ak! Most likely right but ill add my insight. I've had it where i push in my knob to shut off my headlights and sometimes the dash lights stay on as well as the markers. I had to turn the key all the way on and "re-turn" off my lights and the dash lights shut off. Ak is probably right about the radio.. I bet i fudged up my wiring when i fixed the wiring on my radio or maybe its my switch.
