Author Topic: my power steering sings to me...  (Read 3010 times)
ducatipaso
« on: July 13, 2008, 08:44:30 PM »
2000-2500 rpm, wheel to right at about 2'oclock
sometimes
ooooooooooooo....
ooooooooooooooooooooooo...
almost a 440 A pitch
failing pump? the damn rack was replaced about 5 years ago and I splurged for OEM. suck. this is bad timing as my ign cyl died on the 190e.
halcron
« Reply #1 on: July 13, 2008, 11:20:38 PM »
Quote from: ducatipaso;53255
sometimes
ooooooooooooo....
I too have this problem. My pump gets oooo....whheeeeee....oooo when the steering wheel is at neutral. Was told the pump is failing. Now sourcing for an electric PS pump. Wanted to dump the belt driven one.
ducatipaso
« Reply #2 on: July 14, 2008, 12:20:48 AM »
well I guess even if it does fail, it won't be like massively catastrophic. i guess i'll start shopping around.
colin86325
« Reply #3 on: July 14, 2008, 08:56:30 AM »
How's the ps fluid level?  The moan you hear can also be caused by air entering in the front seal of the pump.  You can rebuild the pump for about $30 or so.
ducatipaso
« Reply #4 on: July 14, 2008, 03:51:38 PM »
the fluid level is fine. in fact, there might be a smidge too much in there.
Matt-B
  • Administratorz
« Reply #5 on: July 15, 2008, 01:49:18 AM »
I work at a LUUUUUUbe shop man!
-mA+t B
EN318isPDX
« Reply #6 on: July 15, 2008, 10:07:43 AM »
Quote from: matthew-mayhem;53308
KY or Vaseline?
ducatipaso
« Reply #7 on: July 15, 2008, 10:52:53 AM »
bwahahah nice one guys :: matt you keep your lube to yourself :)
EN318isPDX
« Reply #8 on: July 15, 2008, 10:59:36 AM »
Quote from: ducatipaso;53326
See i had no idea what matt was talkin about so i had to clown on it.. he must be higher than me!
