Author Topic: Massive E30 Sport Kit  (Read 3458 times)
Bunta
« on: July 13, 2008, 07:38:35 PM »
Just got it on this weekend.
11.75" Rotors behind 15" wheels.
No spacers but the calipers needed a little grinding.
Hunter
EN318isPDX
« Reply #1 on: July 14, 2008, 10:18:29 AM »
very nice! how long did it take you to get them in? Those are 4 piston calipers right? how much do they weigh? One last question! How much was the set?
iamcreepingdeath
« Reply #2 on: July 14, 2008, 02:50:55 PM »
that looks good!!!  by the way, what wheels are those, and where do you get them?
Bunta
« Reply #3 on: July 15, 2008, 08:03:56 PM »
They came in about 3 weeks. 4 piston wilwood superlites.  They weigh a fair amount less than stock.  Just the difference in the rotor weight is amazing.
I got the kit from massive because it was the only kit that fit behind et27 15x7 Kosei K1s.  I didnt want spacers or wheels any bigger than a 15".
the rotors are 11.75"
they ended up costing $1158
probably overkill but...
Hunter
kenika65
« Reply #4 on: July 15, 2008, 09:03:20 PM »
Bad azz lift!
Bunta
« Reply #5 on: July 16, 2008, 12:53:43 PM »
Quote from: kenika65;53349
Bad azz lift!
It does its job.  You wouldnt want to do a clutch or much exhaust work on it but it works fine eveything else. I couldnt get a 2 post in the little garage or the car would be in my room.
Still waiting on my stainless lines.  I think im going to get a 25mm master cylinder to frim up the pedal a bit, these brakes push alot more fluid.
Hunter
EN318isPDX
« Reply #6 on: July 16, 2008, 01:09:24 PM »
Those are wicked nice! I bet you can stop on a dime and turn it into 2 nickels! I am way jealous! i want to upgrade my caliper/rotors some day when i have enough power to know i need better brakes!
batsbats
« Reply #7 on: July 16, 2008, 07:00:37 PM »
I am jealous of your garage and a garage equipped with a jack like that
