Author Topic: ADVICE NEEDED E30 M42 Head  (Read 3576 times)
Ex-m20_owner
« on: July 12, 2008, 08:52:41 AM »
Im building a E30 m42 head  but I would appreciate any suggestions, in a mild built head. I am going to use the vw lifters I found the part number for them.  I wanted to know about using the 6MM valves from the E36 m42... are they a direct swap with the 6MM valve guides? I know the valves are the same size but is the length the same? also what other parts would I need. are the valve keepers different? any one help ?
Wise Old Dog
« Reply #1 on: July 12, 2008, 10:18:48 AM »
AFAIK, everything is the same. You can verify the keepers and retainers by going to realoem.com.
Do you have a e36 head to pull parts from?
Why not just rebuild it instead?
Valves are expensive.
The VW lifters work well.
kevo__
« Reply #2 on: July 15, 2008, 06:02:50 AM »
what valve clearance do you run with the vw lifters chaps? and what are the part numbers of them? also does anyone have a how to?
cheers
Kev
Wise Old Dog
« Reply #3 on: July 15, 2008, 06:18:46 AM »
The VW lifters are hydraulic = no clearance
kevo__
« Reply #4 on: July 17, 2008, 01:43:45 PM »
cheers for that, i thought they were solid lifters though? i take it they are just lighter than the bmw ones then?
Kev
Ricer Ennemi
« Reply #5 on: April 18, 2010, 04:56:58 PM »
This thread is old!!!
I'm interseted in this subject.6MM E36 valves in E30 head with vw light lifters.
With good oil pump I should be good to shift @ 7K.
Warsteiner
  • -Receive: 21
« Reply #6 on: April 18, 2010, 07:08:38 PM »
Yes you can use the 6mm valves in the E30 head as long as you of course use new 6mm valve guides:) They are all the same from the S50/S52 M3 and M50's.
~Ralph
