Author Topic: Brake question  (Read 2797 times)
BMWManiac
Brake question
« on: July 11, 2008, 10:54:15 AM »
1991 318i
I am replacing my rotors and pads and I just picked up a pair of cheap pads from Advance Autoparts that says they are for my car.....can anyone confirm or deny that they are in fact the ones I need for my car?  They have a spring of some sort at the top and no three pong to insert into the piston like my M3.....I just want to make sure before I go ripping this stuff apart!
Wearever, MKD 493....on their site, they say for me, but I've never seen pads like this for a BMW.  I can't post a pic, so I've attached the site.
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=WEA&MfrPartNumber=MKD493&PartType=219&PTSet=A
« Last Edit: July 11, 2008, 10:56:23 AM by BMWManiac »
2006 Interlagos Blue Z4M Coupe
Premium pack, navigation, heated seats
1997 Artic Silver M3
Built motor + SC62 + TRM tune
545rwhp/520rwtq
monty23psk
  • -Receive: 17
Brake question
« Reply #1 on: July 11, 2008, 01:32:31 PM »
Mine do not have the 3 prong, but mine are from another company, porterfield. they do have the 2 spring attachement at the back where it rest against the caliper.
BMWManiac
Brake question
« Reply #2 on: July 11, 2008, 05:00:42 PM »
I'm going to just do it and see if the old ones are the same...if not, I'll put it back on.
545rwhp/520rwtq
monty23psk
  • -Receive: 17
Brake question
« Reply #3 on: July 11, 2008, 09:25:05 PM »
go for it, but if they say they are for the car, then they most probably are.
P. Kennedy
Brake question
« Reply #4 on: July 11, 2008, 11:41:51 PM »
Yep, those are the ones for the front.  The rear inner pads have three prongs that insert into the caliper piston.
I just began a massive brake project today.  Pads, rotors, calipers, stainless brake lines all front and rear.
I managed to break 3 of the 4 hard line junctions from the old rubber lines to the steel lines.  Honked me off for sure.
Do I replace the entire steel line(s) or cut, flare and couple new line ends w/fittings and brass unions?  The entire lines are pretty long and convoluted, anyone ever done it?
BMWManiac
Brake question
« Reply #5 on: July 12, 2008, 08:44:11 AM »
As long as it will still reach, I would jsut cut, flare, and put a new couple end....I got them installed....not too much of a problem.
However, I noticed a trend.  When I replaced my driver side rotor on both the 318i and my M3, there was a 'plug' instead of a caliper retaining bolt in the hub!!!!  I had to drill and extract the last one, why do they do this!
545rwhp/520rwtq
P. Kennedy
Brake question
« Reply #6 on: July 12, 2008, 11:37:35 AM »
Thanks.  I was leaning that way for sure.
