Author Topic: Timing Chain Question........  (Read 2098 times)
ukfan4sure!
« on: July 10, 2008, 03:30:49 PM »
How in the world do you take all of the bracketry and gadgets off to get the stupid lower case off my M42 in the 318ti?
Best I can tell is that the freon must be released on the compressor line in order to get a correct (not angled) bite on the allen socket screw that holds the top of the compressor.  Then once the compressor is out of the way, you have to get up in there and take the compressor bracket off.
This sure seems like a long way around and extra expense refilling the A/C.  Kind of sucks IMHO.
Anyone got pics or advice?  I am about to pull my hair out thinking how stupid this whole sha'bang was designed.  :eek:
nicknikolovski
« Reply #1 on: July 11, 2008, 04:03:30 AM »
Hi, after reading through the E30 M42 chain replacement guide, I stumbled upon the same problem for my E36 M42. The damn A/C compressor bracket that bolts to the block covers a 10mm bolt that needs to be removed to get the lower timing cover off.
What you need to do is unbolt the A/C compressor off the bracket, lift the compressor by the lines, (don't worry the lines are fairly strong) and move it up and out the way. Then you have to unbolt the A/C compressor bracket off the block (the biggest pain in the ass). Then you can get access to the lower timing case.
You will also need to remove the 5mm allen key bolt that holds the crank sensor in place. (this can also be a bit a pain).
Good luck.
