e36 m42 into e30
Author Topic: e36 m42 into e30  (Read 3042 times)
91318isfoundation
e36 m42 into e30
« on: July 10, 2008, 03:04:27 PM »
must i change the wiring harness for this procedure? anything else i should consider? engine is in transit to where my car has been sitten for 1+ yrs now
hesgone2fast
e36 m42 into e30
« Reply #1 on: July 10, 2008, 03:21:53 PM »
Please do a little search first...
http://m42club.com/forums/showthread.php?t=6071
You have to change complete intake manifold, oil pan, oil pick up, complete wiring harness, and ECU.
Good luck!
E30nate
e36 m42 into e30
« Reply #2 on: July 10, 2008, 11:10:31 PM »
Quote from: hesgone2fast;53080
Good luck!
if you are putting it into an e30 you keep the stock wiring harness & ecu. you only need to change the other mentioned stuff.
hesgone2fast
e36 m42 into e30
« Reply #3 on: July 12, 2008, 05:54:44 AM »
Quote from: E30nate;53109
That´s what I meant, you need to use the E30 wiring harness, I said change the complete wiring harness reffering to the E36 engine harness.
91318isfoundation
e36 m42 into e30
« Reply #4 on: July 22, 2008, 12:30:32 PM »
why is it that the oil pans must be changed?? cuz i actually dont have the oil pan from my m42 that im taking out...
E30nate
e36 m42 into e30
« Reply #5 on: July 23, 2008, 12:54:43 AM »
the e30 has a two piece oil pan with the sump in the front. the e36 has a single piece oil pan with the sump in the rear.
