Intake swap e36 to e30
Author Topic: Intake swap e36 to e30  (Read 5931 times)
x5driver
« on: July 07, 2008, 11:20:38 AM »
Do I have to swap the intake manifold from a '91 m42 to drop in a '93 m42 in my e30?
I'm taking the 242k mile engine out of my '91 318is and putting in a 127k mile '93 318i.  I'm swapping the mounts, ps, a/c, ect..
1)Will the e36 engine harness plug into the e30 computer?
2)And do you have to swap the intake manifolds?
Those are my two questions. Thanks for any help.
HMS_Tim
« Reply #1 on: July 07, 2008, 12:11:23 PM »
Quote from: x5driver;52819
You will have to use the e30 intake.  e36 is too tall. I think you will have to use the e30 valve cover also.  Due to the velt fitting located at the rear of the e36 valve cover.  e30 is in front.
I just had to do this myself yesterday.
Besides, you get a little more torque out of the e30 intake, which is needed anyways.
Don't know about the wiring harness.  Should just plug in... :confused: I guess??
Check out the search function.  There is more detailed info on some other threads.
Wise Old Dog
« Reply #2 on: July 07, 2008, 01:41:06 PM »
IIRC the oil pans are different. Maybe the pick-up tube as well.
Time to put some loc-tite on the pick-up bolts and anything else internal.
The E36 may also have the serpentine belt. Which is good if you have all the accessories.
HMS_Tim
« Reply #3 on: July 07, 2008, 02:07:26 PM »
Quote from: Wise Old Dog;52828
Yeah! What he said.
kenika65
« Reply #4 on: July 07, 2008, 08:36:50 PM »
Serpentine e30 that is what I need wonder if they make underdrive pulleys for the serpentine?
x5driver
« Reply #5 on: July 07, 2008, 09:28:50 PM »
So are you saying that I need to swap the oil pan and pick-up also?
Thanks for all the help guys.
hesgone2fast
« Reply #6 on: July 08, 2008, 02:29:33 AM »
You will have to swap complete intake, maybe the throttle body (different position of the sensor, and different angle of vacuum feed line. There is a thread about this) oil pan, pick up, complete wiring harness.
About the serpentine belt, if you want to use it (assuming the E36 engine comes with it...b/c not all E36 had serpentine belt), you will have to bend the dipstick, as it will be in the way of the belt.
The valve cover is the same, it is different in the M44, but not on the early M42 E36.
I hope this helps!!
HaNasich
  • OO==00==OO
    • http://www.bangbros.com
« Reply #7 on: July 08, 2008, 07:55:00 AM »
Quote from: HMS_Tim;52823
WRONG!
you only need to swap the oil pans.
ce tut.
intake will sit just fine under the hood in the E30, valve cover will do as well.
 - check out my pictures (1990 M40 to 1996 M42 or Vladi's 1991 M40 ro 1994 M42 engines....)
Enjoy.
Ron.
WowMom
BTRA!
HMS_Tim
« Reply #8 on: July 08, 2008, 11:24:25 AM »
Quote from: HaNasich;52911
WRONG!
ce tut.
Enjoy.
Ron.
I stand corrected...
91318isfoundation
« Reply #9 on: August 30, 2008, 10:10:08 PM »
any one got a write up for swapping the pick up and oil pan?>
nelsone30
Re:Help
« Reply #10 on: November 30, 2008, 11:35:56 AM »
Anyone can tell me if im running e36 year 96 m42 to e30 m40 can i use back the e30 m40 wiring harness?
hesgone2fast
« Reply #11 on: November 30, 2008, 02:36:37 PM »
Like said above, NO, you can not use the M40 wiring for an M42. Basically because aside from the block, it´s a completely different engine... 8Valves/16Valves...
The M42 engine(E30 or E36) can only go into the E30 chassis with the E30 M42 wiring harness.
nelsone30
Re: Thanks
« Reply #12 on: November 30, 2008, 07:51:08 PM »
Thanks for the info. In my country doesnt have m42 wiring harness for e30 so i have to use a e36 wiring harness do you have any idea bout that. And also my engine is from a auto e36 so did the DME link with the gearbox?
hesgone2fast
« Reply #13 on: December 01, 2008, 04:44:10 AM »
Quote from: nelsone30;61991
As far as I can tell, the E36 harness is not a direct fit(I would say it wont work...)The E30 does not have knock sensors, the E36 has electric valves for vacuum operated intake and the E30 doesn´t.
