Author Topic: Does MM offer Custom Pistons & Conrods  (Read 2545 times)
futron.sim
« on: July 06, 2008, 08:57:51 AM »
I tried emailing them several times regarding this but I didn't get any reply thus i am posting here (I live in Singapore so its quite impossible to call them).
I am planning for an engine with MM pistons and conrods as well as crank (unless I can find the crank elsewhere). However, I am looking at a compression of 10:1 rather than 8.6:1, thus I am wondering if MM or any other companies offer a compression of 10:1 for the M47 crank configuration.
Thanks!
hesgone2fast
« Reply #1 on: July 07, 2008, 02:46:54 AM »
Well, how about something like this:
http://cgi.ebay.com/ebaymotors/EAGLE-ESP-HBeam-Connecting-Rods-BMW-M40-M42-M44-motor_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ33623QQihZ024QQitemZ370013040223QQrdZ1QQsspagenameZWD1V
H-beam rods, stock dimensions, so they fit the M47 crank.
About pistons, you could try M3 pistons(either S50 or S52) need to bore the block, but more displacement...and cheaper.
There are lots of combinations to do.
nuvolarossa
« Reply #2 on: July 08, 2008, 02:57:59 AM »
they are not stock dimension, but those on ebay are 5mm shorter than stock.;)
