Author Topic: Steering wheel/airbag ?  (Read 6317 times)
Sam Cogley
« on: June 24, 2008, 03:35:03 PM »
Dumb question, I've searched several sites but haven't found much.  Will an E36 steering wheel and airbag fit and work in place of a stock '92 318iC steering wheel and airbag?
twinpop171
« Reply #1 on: June 25, 2008, 09:05:57 PM »
I don't think they are interchangable but maybe someone else here can chime in.
Dan.
Brillantrot 1991 318is
« Reply #2 on: July 06, 2008, 09:22:54 PM »
No, it won't. The splines are different and the airbag controller in the the e36 is a bit different. I believe e34 wheels will work though. Or maybe you should just ditch the airbag ;)
Sam Cogley
« Reply #3 on: July 07, 2008, 04:16:35 PM »
Quote from: gearheadE30;52761
I'd rather just have an M-Tech wheel...I don't think the inspection guys would be too appreciative of a missing SRS system, though.
« Reply #4 on: July 08, 2008, 10:57:24 AM »
Would they even notice? Pull the check panel light and other obvious SRS stuff and you might get by.
jrobie79
« Reply #5 on: July 22, 2008, 11:39:21 PM »
what other stuff would you need to pull, i did the check panel light, but i dunno of anything else that would give it away? i got an inspection coming up and dont wanna fail cause of that and i really love not having that airbag wheel.
Asbradley21
« Reply #6 on: July 25, 2008, 05:28:31 AM »
Well, there is the airbag thats in the glove box, as well as the impact sensors under the bonnet.  But none of those are exactly obvious.
jrobie79
« Reply #7 on: July 26, 2008, 12:58:46 AM »
Quote from: Asbradley21;53793
airbag in the glovebox? i thought the airbag e30s were only driver side airbags....
Asbradley21
« Reply #8 on: July 26, 2008, 02:45:17 AM »
Wise Old Dog
« Reply #9 on: July 26, 2008, 08:11:24 AM »
The impact sensors stand out like a sore thumb with the bright color. A competent inspector will notice them.
We are talking about an E30 right?
« Reply #10 on: July 28, 2008, 12:48:10 PM »
There is no airbag in the dash, that is just where they happened to put the sticker. If you want to do a full delete, do the check pull out the controllers located above the driver's knee bolster, remove all associated wiring and the impact sensors, and pull that sticker in the glove box. This includes the airbag plug and wiring that runs along the steering column. I'm not sure if there is anything else airbag-related in there.
Asbradley21
« Reply #11 on: July 31, 2008, 06:28:45 PM »
Quote from: gearheadE30;53923
Oh, I'ma rip that sticker off then, I don't have an airbag anymore.
EN318isPDX
« Reply #12 on: July 31, 2008, 06:32:02 PM »
Personally i want to get rid of my ugly steering wheel but i still want to get the insurance discount for "having" SRS equipped
