I decided to put my car on a diet so along with removing all the carpet and tar I took out the sunroof cassette/motor assembly. I reused the stock panel as opposed to using the carbon fiber panel sold on ebay. $250+ is steep for me! :p
That said, I made brackets to hold up the panel and I thought I'd share it with you guys. I went off of a few DIY on Bimmerforums. Some were way more complex than it needed to be and some were quite simple yet completely functional. Decided to go with the latter.
A few things I did do differently from the DIYs:
1) I used 1/8"x 1 1/2" steel flat stock as opposed to aluminum. MUCH stiffer yet still flexible enough for the application.
2). I used pop rivets instead of machine screws. I just don't feel confident about screws hold onto quite thin sheet metal. Not to mention the possibility of it denting the roof if you're not careful with length. The rivets I used were 3/16 inch and the majority of which had a "grip range" of 1/4 inch. I did have a few 1/2 inch just in case. I also reused the torx bolts from the cassette along the front (towards the windowshield) of the steal straps.
On the outside, I masked off the roof and panel area around the opening and laid a bead of silicon sealant. Did the same inside.
The cassette is about 25-30 lbs, panel is about 5 lbs and motor is about 2-3 lbs. Honestly I do feel a difference when cornerning.
Consider the fact that the weight came off the top of the car and it'll make sense.
If anyone wants additional or specific photos, feel free to let me know. Also any questions, specific measurements, info requests ect...are more than welcome!
