Author Topic: Stomp Test?  (Read 5565 times)
eric16v
Stomp Test?
« on: June 23, 2008, 01:30:56 AM »
so ive been reading about people doing a "stomp test" to get codes. can someone please explain how this test is done?  thanks in advance!
RouteZeroDesign
Stomp Test?
« Reply #1 on: June 23, 2008, 05:27:02 AM »
Couldnt resist :)
Ive never heard of a 'stomp test'. What codes are you trying to get OBD codes?
adam12hicks
Stomp Test?
« Reply #2 on: June 23, 2008, 07:31:19 AM »
Turn the key to the position just before ignition and press the gas pedal 5 times.  Wait a second.  You'll get one long light and then it will start rattling off codes if there are any.  Write them down.  It'll be codes like '1272' etc.  Then you can quickly find a cross reference all over the internet.
Something I DON'T know how to do though (unless pulling the battery is the only way?) is to clear the codes to see if they are just old codes or still active.
2005 X5 3.0 (kid hauler)
big red
Stomp Test?
« Reply #3 on: August 21, 2008, 10:10:29 PM »
Search "oil service light" by cobra jet. I just did it,(after a year and a half :( ) Worked perfect. Sooooooo nice to see those green lights. Thanks to those who posted it.
Stomp Test?
« Reply #4 on: August 22, 2008, 07:08:43 PM »
I get rid of codes by unplugging the battery lol.  You can also jump some connections with a wire and reset the oil lights/codes.
RED IS 91
Stomp Test?
« Reply #5 on: August 23, 2008, 05:45:02 AM »
Quote from: eric16v;51824
Here's the link to tell you all about the test and how to perform it ..........
http://www.pelicanparts.com/bmw/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm
quinn11m20
Stomp Test?
« Reply #6 on: August 23, 2008, 01:05:08 PM »
The computer resets itself every 60 starts. Also 1444 is the code for NO FAULTS FOUND. that means the check engine light flashes once, pause, four times, pause, four times.....etc. the rest you can RED IS 91's link. K
