Author Topic: Help! Engine code 1271 says 'Ignition Coil 1' has an issue (?)  (Read 2647 times)
adam12hicks
This was found during a stomp test.  I don't notice any missing or hesitation, but I'd like to check the contacts and test a known good coil.
My problem is I'm not sure how to tell which coil is 1, 2, 3 and 4?  Does anyone have a quick diagram that shows which coil is which?
Thanks!!!
2005 X5 3.0 (kid hauler)
ClodKing
« Reply #1 on: June 20, 2008, 03:37:53 PM »
There should be numbers stamped into the plastic that surrounds the coils.
twinpop171
« Reply #2 on: June 20, 2008, 08:28:47 PM »
Wouldn't plug number 1 be connected to coil number 1?
Brillantrot 1991 318is
adam12hicks
« Reply #3 on: June 21, 2008, 12:29:44 AM »
Now stamped numbers are handy :)  Sorry I'm sure plug 1 goes to coil 1, but to be honest (and I'm not afraid to admit it) I don't know if the cylinders are 1-4 front to back or back to front, so I wanted to check to be sure before making any assumptions.  I can do a lot of work on these things, but I don't do block work.  I pay someone for that...
Thanks!
sepehr
« Reply #4 on: June 21, 2008, 02:32:49 AM »
I believe the cylinder numbers go front to back.
