Author Topic: Active check panel vs. plain m42 panel  (Read 4189 times)
Sam Cogley
« on: June 19, 2008, 02:23:27 PM »
Is it possible to retrofit the full check panel to a 318?  What would be involved?  I tried searching for information, but couldn't find much.
BMWManiac
« Reply #1 on: June 24, 2008, 08:29:35 PM »
I'm in the same boat....I have just a panel and when I plugged it in, it would flash "SRS."  I bought a check panel on ebay and hopefully, it plugs right into the same connector....I'll let you know!
2006 Interlagos Blue Z4M Coupe
Premium pack, navigation, heated seats
1997 Artic Silver M3
Built motor + SC62 + TRM tune
545rwhp/520rwtq
« Reply #2 on: June 24, 2008, 10:38:58 PM »
You can fit the panel, but to get it to actually function is a fair amount of work - we don't have much of the wiring that supports the full-blown check panel. Check relays, etc., are not present in our cars.
nomad
« Reply #3 on: June 28, 2008, 07:49:45 PM »
I don't feel like doing the wiring work on mine.
If I don't sell my SRS check panel I was going to use I'll just put it in the M42 to make the upper panel "look more interesting'. It always looks like something is supposed to be there...
SoCal, 318is: IT RUNS AGAIN!
BMWManiac
« Reply #4 on: June 29, 2008, 01:03:40 PM »
Is there a light fixture that can go in its place if the check computer doesn't work there?
545rwhp/520rwtq
« Reply #5 on: July 06, 2008, 09:17:21 PM »
I took one out of a silverado. Others have done VW dome lights, I believe. Just run a set of wires above the headliner to one of the stock lights. Mine's even got maplights ;). The interior subforum has a few more pics. These maplights are even aimed right at the driver/passenger's lap. Pretty good for $5.
BMWManiac
« Reply #6 on: July 07, 2008, 09:12:44 AM »
I just got my check panel and the connector is different....anybody want a check panel?
545rwhp/520rwtq
Cobra Jet
« Reply #7 on: July 08, 2008, 10:24:15 AM »
What harnesses or wiring would be needed to actually retrofit the fully functional E30 325 check panel into a 318?  is it really that hard or complicated to do - even if having to make your own wiring?  I often wonder why BMW did not include a full function check panel in the 318's...
Does anyone have a wiring schematic of the 325 check panel to see the wire layouts as to how it operates?
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
nomad
« Reply #8 on: July 08, 2008, 01:17:23 PM »
I have an SRS version of the check panel. Since our 318is has the seatbelt and srs lights standard (there are lights for "airbag" and "overheat" included but not hooked up) I think it can work.
If I don;t sell it then I'll probably take the circuit board out of the 318 one and put it in a gutted check panel. I can solder small wires to the other srs and seatbelt light locations so that they'll light up just like the original.
Certainly all of the lights won't necessarily work but I wonder if you could jump a 12v and a ground to it so that at the minimum the lights could work when you tap the check button?
