Author Topic: o2 sensor code  (Read 1734 times)
stever318is
o2 sensor code
« on: June 17, 2008, 10:22:24 AM »
can a faulty o2 sensor cause a temp gauge to malfunction.  Car runs horribly as temp gauge passes 3/4 then check engine light comes on, push clutch in downshift and gun it check engine light goes off power returns gauge returns to halfway.  Did the pump pedal 5 times to get o2 sensor fault code. Note temp gauge is erratic at times always corresponding with misfire past half point.
idea's??
steve
91 318is
87 325i
88 325
