My M42 turbo build
Author Topic: My M42 turbo build  (Read 15312 times)
rob_e30
My M42 turbo build
« Reply #15 on: June 26, 2008, 11:14:00 AM »
Quote from: nomad;52050
speaking of budget, what was the cost of it so far? If you got any wild deals then what would the cost be at average used prices?
Never add it all up!
George77
My M42 turbo build
« Reply #16 on: June 26, 2008, 05:24:19 PM »
Quote from: Jimmy Lewis;52047
I'm curious of how you are adapting emanage to suit your tuning needs. The idea of using another elbow added to the cut m50 manifold was something I thought may solve the issue of hitting the strut tower, glad to see it actually is something that works, haha. This is exactly the kind of build I like, low budget but very well thought out. Have any more details regarding the build, I have looked at all of your pictures but some more insight would be great!
I'm running 10psi with emanage controlling the fuel and spark,the hardest thing it's to make it suit to control the ignition timing,because this thing it's desingt
for japoneze cars witch has a 5V signal going out to coils.You have to interrupt the low signal before the amplifying transistors and go in the emanage and the out signal from the  emanage to go in the transistors. And there is another thing,you need some resistors for the injection wiring harness or you will get error codes.
12PSI of boost on stock engine
George77
My M42 turbo build
« Reply #17 on: June 26, 2008, 06:13:36 PM »
the budget was quite low because I got the turbo,injectors and the intercooler for free,other wise I would go with a BIGGER turbo,with this one it's like a factory turbo car,but that's for the upgrade project.As for the price:
Exhaust manifold   150$
emanage the unit     200$
All harnes and pessure sensor for emanage     500$
metal plates, for flanges  30$
3" exhaust pipes with clamps 100$
muffler 120$  on sale
2.5" piping kit    150$
wide band kit LC-1  280$
About that free stuff ,I'm mechanic  at a garage specialized in Volvo, VW,it's just me and the oner,but I'm a 10000% bmw guy,I love bmw
« Last Edit: June 26, 2008, 06:19:11 PM by George77 »
Trent
My M42 turbo build
« Reply #18 on: June 27, 2008, 05:36:59 AM »
If you ever wanna get another "kit" together and sell it I'd definitely be interested!
Nice job
sumyungguy
  • b.wood
    • http://www.shutterflick.com
My M42 turbo build
« Reply #19 on: June 30, 2008, 12:52:56 AM »
Quote from: George77;52085
If you could possibly post a wiring diagram of what you did that would be awesome and much appreciated. I have access to the units and have stuff for a turbo kit literally lying around, the management has been holding me back.
brad™
George77
My M42 turbo build
« Reply #20 on: July 05, 2008, 09:26:40 PM »
Quote from: sumyungguy;52286
I'll try to post some diagram ,if you have some soldering and some electronic knowledge it won't be hard.
George77
My M42 turbo build
« Reply #21 on: July 05, 2008, 09:35:28 PM »
After 3 days of fights with the LC-1  I managed to make it work properly .This thing it;s so sensible to the power ,if the power  drops to much during the cranking goes in recalibration again and because the engine is running it doesn't recalibrate right ,the O2 sensor it's supposed to be in free air during the calibration.
George77
My M42 turbo build
« Reply #22 on: July 05, 2008, 10:04:16 PM »
I just drawn a sort of diagram. http://s284.photobucket.com/albums/ll4/george318/?action=view¤t=Untitled-1.jpg  Can someone tell me why I can't post pictures directly I need some help with that.Do I need 10 000 posts or something????????
George77
My M42 turbo build
« Reply #23 on: July 05, 2008, 10:16:34 PM »
and here a picture  http://s284.photobucket.com/albums/ll4/george318/?action=view¤t=IMG_1055.jpg where you can see how I cut the left transistor's leg and get the signal from circuits board ,go with the signal in the IN of the emanage and the out of the same channel go back in the transistor's leg.
« Last Edit: July 05, 2008, 10:20:51 PM by George77 »
kenika65
My M42 turbo build
« Reply #24 on: July 06, 2008, 12:08:56 AM »
Brilliant and simple I love it, a detailed how-to would be very popular!
Keep us posted on the progress!
To add a photo click the little yellow box with the mountains when in advanced mode. and past the picture location.
sumyungguy
  • b.wood
My M42 turbo build
« Reply #25 on: July 06, 2008, 02:20:48 PM »
Thanks!!
brad™
asuj158
My M42 turbo build
« Reply #26 on: July 30, 2008, 01:25:02 AM »
how hard would it be to do this with an e36?
George77
My M42 turbo build
« Reply #27 on: July 30, 2008, 07:34:56 PM »
To do what??The turbo thing or just the emanage adaptation??
asuj158
My M42 turbo build
« Reply #28 on: July 30, 2008, 07:48:12 PM »
everything, would it all be the same?
s_ribs
My M42 turbo build
« Reply #29 on: August 09, 2008, 11:17:08 AM »
This is the second time I have seen people using M/S50 ebay manifold with the extra 2 cylinders cut off.
Curious if you have any more thoughts on going that route vs. buying one specifically for the M42.  Obviously price is the biggest factor.  Power numbers could potentially be lowered or at least not optimal..... but if that were the case cost would outweigh the loss (which would be minimal I would guess).  Any fitment issues using that manifold trimmed down?
Thanks!
