Author Topic: M50 turbo manifold on M42 fitment  (Read 11097 times)
omar85
« on: June 08, 2008, 10:16:40 PM »
Can anyone confirm that this manifold will fit. I plan to cut the last 2 runners closest to the turbo flange off and place the turbo just in front of the motor. I was going to just buy it but i figure i would make sure. i know there is not much m42 turbo knowledge out there but any help is appreciated.
i emailed the sellers for dimensions and didn't get a response.
http://cgi.ebay.com/ebaymotors/BMW-E36-M3-323-325-328-T3-TURBO-MANIFOLD-NEW-Stainless_W0QQcmdZViewItemQQcategoryZ36474QQihZ010QQitemZ200229454456QQrdZ1QQsspagenameZWDVW
« Reply #1 on: June 08, 2008, 10:30:30 PM »
Google ROCKZ!!!!11
omar85
« Reply #2 on: June 08, 2008, 11:32:16 PM »
i very much appreciate your help. i plan to run a top mount but that really helps as far as fitment between the head and the strut tower.
George77
« Reply #3 on: June 09, 2008, 02:07:06 AM »
Yes it does,I'm using one for a top mount,you just need to buid an adaptor betuin the manifold and turbo.I tried to put some pictures but I couldn't,maybe I need more posts???
12PSI of boost on stock engine
omar85
« Reply #4 on: June 09, 2008, 09:31:55 AM »
Quote from: George77;50837
do you have the same setup i described plus the adaptor. why do you need an adaptor. i was going to use one anyways because its a T25 flange turbo.
if you can please send pictures to me at o_alcha3@hotmail.com that would be very appreciated.
George77
« Reply #5 on: June 09, 2008, 07:07:52 PM »
It's an adapter made by me because the turbo needs to stay higher then the manifold's flange
omar85
« Reply #6 on: June 09, 2008, 10:24:38 PM »
here are the pictures that george sent me. very helpful and easy to do. thanks again man.
