Author Topic: Carpet rejuvenation.  (Read 10054 times)
Alexx
« on: June 08, 2008, 02:55:59 PM »
I would like to restore my carpet to it's original condition if possible. I would like to get a procedure on how to clean and restore my carpet. It is for the interior carpet inside the BMW 318is. I heard about a paint or a dye that you spray on the carpet after washing it and the result is pretty impressive. I would like to get a link on how to rejuvenate my carpet.
rhogg
« Reply #1 on: June 08, 2008, 10:21:39 PM »
I just "painted' my carpet this weekend.  It was a badly stained grey carpet and all I did was thoroughly vacum it and then spray on a couple of coats - I was amazed.  The hardest part was removing the carpet from the car.  I bought 3 cans of the paint at Canadian Tire @ $8/can.  The paint is called Vinyl and Fabric paint.
Alexx
« Reply #2 on: June 09, 2008, 01:37:40 PM »
I would also like to get a link on how to remove my carpet properly. I have looked in the service manual but there was nothing that could help me. I do not want to destroy anything.
rhogg
« Reply #3 on: June 09, 2008, 02:40:35 PM »
Well I searched extensively for a removal DIY with no real luck. Here is my attempt
1) Remove front seats 4 bolts each remember the wire on the driver side
2) Remove rear seat ( you can do this last and have something to rest on in the meantime.  Pop the bench out Two 10mm bolts at the bottom each side hold in the seat back. They are hidden under some fabric. Then lift up of the two back hooks - takes some strength
3) Remove Parking brake boot lift from front
4) Remove rear console: remove ashtrays one 10mm bolt at back then lift from back
5) Remove front console: Pop out shift boot Remove ashtray and the two screws  remove the two trim plugs one on each side ar the front near the fire wall.  I had a screw in to the passenger side that needed to be removed from the inside. I had to pry up the left side and squeeze my hand in with a screw driver to get it - it was a b****
6) Remove the front speaker panels. One screw and pull
7) Loosen the trim peice with the seatbelts.  Two trim plugs each at the bottom.
8) Door sills.  I did not get these out and broke one trying to pull them out. I ended up just pulling the carpet out from underneath them.  I still need to figure this part out but you do not need to remove them to remove the carpet
9) OK start at the back and pull the carpet away from the sides.  The foam is bonded to the back of the carpet so it can be awkward.  You should be able to free the carpet everywhere except the gas pedal and the metal bar that holds up the dash.
10) Gas Pedal: Pry out the circlip on the linakge behind the pedal and pull the connection apart.  Look at the back of the gas pedal you may have a clip that you can push down on and release the pedal. On mine there was no clip and I ended up pulling the carpet over the pedal.
11) Unscrew remove the clutch and gas pedal stops
12) There are a couple of grommets on the sides near the back of the front seats. One was missing on mine and the other I just pulled the carpet over.
12) Your carpet is now free except for the metal post and the front portion.  In my searches people said to cut the carpet at this point.  I did for but would have been able to pull it out from under the heater box. - Some claimed they couldn't.  I would try to pull it out first.  The post would be easy to disconnect I think if you were not cutting the carpet.
 Thats it the capet can be removed. With the large amount of foam it is awkward but it comes out.  This is from memoory but I did this 5 days ago jsut feelign my way forward so you shoudl be good to go.  I found a floor in very good condition although with soaked foam under the driver mat that has taken a couple of days to dry out.
The rear peice of carpet just lifts out if you have the back bench removed
You can ask about installation tomorrow. I think the foam will be dry enough to reinstall this afternoon. It was painted this morning :)
Alexx
« Reply #4 on: June 13, 2008, 12:03:00 AM »
What kind of paint do I need to paint the carpet ?
rhogg
« Reply #5 on: June 13, 2008, 11:05:49 AM »
" I bought 3 cans of the paint at Canadian Tire @ $8/can. The paint is called Vinyl and Fabric paint."
It is a generic paint among all the other auto spray bombs at Canadian Tire. You have  a choice of black or grey. I used grey and used 2 cans to do my very badly stained carpet.  This was enough for 2 complete coats with additonal coats to fully cover and blend the badly stained areas.
I did not "brush" between coats as some suggest.
I did paint the vinyl kick pads as well
adam12hicks
« Reply #6 on: June 13, 2008, 01:14:32 PM »
Weird I can't find a Canadian Tire ANYWHERE near Dallas?  :)
2005 X5 3.0 (kid hauler)
318kid
« Reply #7 on: June 13, 2008, 05:29:49 PM »
Quote from: adam12hicks;51210
Haha... There is some that's like that except the brand is Duplicolor. Just walk into any autoparts store, and if they're decent then they should have it.
Alexx
« Reply #8 on: June 14, 2008, 06:15:24 PM »
It seems that my heater core is in the way. Do I need to cut the carpet ? If so, where do I cut ? Help is greatly appreciated.
« Reply #9 on: June 14, 2008, 06:20:05 PM »
It is FAR easier to cut the carpet - I just did it without cutting, and it was such a huge PITA that I wouldn't do it that way again; AR though I am, it ain't worth the grief!
Cut as high up around the heater box as you can get, there are openings for the drains and such that you can just follow along.
Alexx
« Reply #10 on: June 14, 2008, 06:44:22 PM »
Thanks for the quick repy. I would like to have a procedure if possible. There must be a procedure somewhere.
P. Kennedy
Paint
« Reply #11 on: June 14, 2008, 07:24:49 PM »
I painted mine too.  Made a a big difference.  Found Carpet & Vinyl paint at AutoZone.
rhogg
« Reply #12 on: June 15, 2008, 12:53:43 AM »
...and there' s a good reason for that!  There would be one near Alex though.
Alexx
« Reply #13 on: June 17, 2008, 09:47:45 AM »
At last, I have managed to get the carpet out of the car. Under my carpet, I saw two round holes. What should I do next in order to complete my carpet rejuvenation ?
rhogg
« Reply #14 on: June 17, 2008, 11:46:41 AM »
????? get new floor pans...
There are a number of drainage holes with plugs in the floor pans.  If you have two that are open the plugs are gone.  You can likely get generic plugs at ... Canadian Tire... or order specific ones.
You want them closed because if they are open they will contribute to rust - especially in Montreal.  Clean up any rust you see and put a good primer /paint on it.
Other than that your next steps are vacum, spot clean if you like, and then spray.
